Author Topic: 350/305 help  (Read 8737 times)
Offline mickey
350/305 help
« on: December 03, 2007, 06:48:33 pm »
trying to find out a way to visually look at a 305 or a 350 and know what you have.
Also any other ideas on how to figure out what motor i have in this truck.
It is a 86 4x4. the guy i bought it from swears it is a 350. but then he is defently not the sharpest knife in a drawer.
Thanks for any help in advance
Re: 350/305 help
« Reply #1 on: December 03, 2007, 06:49:54 pm »
Pull the engine code off the engine.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: 350/305 help
« Reply #2 on: December 03, 2007, 09:52:01 pm »
Look at the starter bolt pattern.
350-off set two bolts--one in front, diagonal from the other.
305--two bolts in line paralell with the end of the block.
Offline eventhorizon66
Re: 350/305 help
« Reply #3 on: December 16, 2007, 09:19:45 pm »
I pulled the starter off my old 305 and bolted it to the new 350 Goodwrench motor I put in this summer.  Both offset style.  What's up with that?
'85 C10 SWB 350 700R4 TKO600
Offline baggedk5
Re: 350/305 help
« Reply #4 on: December 26, 2007, 09:36:35 pm »
Cant really go off the bolt pattern of the starter. pull the casting numbers off the block, behind the driver side head. Goolge the numbers, "chevrolet casting number 3970010" for example. Usually you can gather motor c.i info, yr, and vehicle it was factory in. using the other casting numbers and marks, found various other places on the block, you can get the manufactured date, and plant info.
I reject your reality, and substitue it with my own!
Offline 87GMC2WD
Re: 350/305 help
« Reply #5 on: December 31, 2007, 09:07:21 am »
or if its the original motor check the sticker that has the emissions on it and it should say either 5.0 or 5.7
Offline 84chevysilverado
Re: 350/305 help
« Reply #6 on: November 16, 2008, 03:45:10 pm »
heard sowhere that on a 305 the dipstick is on the passanger side and a 350 is on the drivers side.
Re: 350/305 help
« Reply #7 on: November 16, 2008, 06:12:01 pm »
This is a pretty old post but the info you were given is wrong.
