Author Topic: Unique 1980 rectangular headlamps  (Read 12948 times)
Offline got2haul
« on: December 20, 2007, 10:56:31 am »
I'm curious as to what it would take to convert my Custom Deluxe model grille with round headlamps to the Silverado-style rectangular headlamps that were unique to 1980 models.  Parts required -- headlamp bezels, turn signal lamp assemblies?  What about the gille and radiator support?  Will rectangular headlamps bolt on, or is there some kind of adapter, or do you need to replace the entire radiator support?  Anyone done this conversion that can provide some insight as to what's involved and what new parts are required?
1980 Custom Deluxe Stepside
        Stepside thread: http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
Offline nova801428
Re: Unique 1980 rectangular headlamps
« Reply #1 on: December 20, 2007, 12:01:01 pm »
Looks like pretty much the front assembly.  I was going to get this one but I am still trying to decide if it's worth it.  Here's a pic.
1975 Chevy k20 6" lift 35" BFG MT's True Dual Exhausts Radical Cam
1980 GMC 2500 Parts Truck
Offline ccz145a
« Reply #2 on: December 20, 2007, 12:48:16 pm »
From what I have seen, all it takes is the bezels and the headlamp buckets and park lamp assembly if have the 79 frontend, if you have the pre-79 front, then you would need the big chrome piece below the grill as well. And everything should just fasten right up to your existing core support and sheet metal.
-chip
Offline Dragon
« Reply #3 on: December 20, 2007, 02:34:48 pm »
You should be able to get all the parts for the conversion through  .  As suggested, you will need new headlamp buckets,bezels, and Park Lamps. 73-80 trucks used the same basic radiator supports, but you may need to drill new bucket mounting holes if different...  Grilles were pretty much the same between 79-80's(Even earlier in most cases)...
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline 80stepsideguy
« Reply #4 on: December 20, 2007, 08:13:59 pm »
Judging by the year you got in your signature i see you got a 80 already and it has the rounded headlights.Well to change it to the square i say it needs the headlight buckets(the ones that hold in the headlights, the headlight retainer rings, and the headlight trim piece and thats it.I know its just a opinon but to me the look of the rounded headlights are better, i am just not into the square headlights.But to each there own i guess.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline bowtieguy
  • Country as a Cow Pie
« Reply #5 on: December 20, 2007, 09:44:19 pm »
I like the Square head light look.  Go for it!   /Chevy/Year One etc, should have all you would need for a swap, or a local salvage yard.
Toys:
89 Black Lesabre T 62k miles
03 Lesabre Celebration Edition
08 NNBS CC Z71 LTZ
79 Flat BlackChevy C-10  5.3/4L60E
« Reply #6 on: December 21, 2007, 05:01:19 am »
I never cared for the square light look. I think they look way too much like the old Dodge trucks.
Offline got2haul
« Reply #7 on: December 21, 2007, 06:51:11 am »
I'm not 100% decided on this conversion yet -- in fact, I changed the 1979-1980 (round) headlight bezels and lower grille trim to the 73-78 style, and the grille to the 1977-1979 style as soon as I got this truck; however, now I'm not sure I really want to stray too far from the truck's original appearance, at least as far as its model year goes.  I have recently reinstalled the original 1980 egg-crate style grille and refinished the headlight bezels, as well.
This conversion may be in the truck's future, but I just haven't made up my mind yet.  A lot will depend on how difficult it is to get original GM parts, and their cost.
« Reply #8 on: December 21, 2007, 01:20:46 pm »
AFAIK, You only need the Bezels and the buckets to do the switch.
