Author Topic: 83 c10 re-innovated Pro Touring  (Read 516856 times)
Re: 83 c10 re-innovated, air ride
« Reply #420 on: January 22, 2015, 07:27:33 pm »
Nice work!
Offline the dan
« Reply #421 on: January 22, 2015, 08:44:57 pm »
Nice work!
Thank you, heres the rest:
Indexed every hole, blueprinted the pulley, and machined the pulley and flange
Officially the only one with a 6.5" 8 rib KRC pump lol
« Reply #422 on: January 22, 2015, 08:47:31 pm »
sweet
« Reply #423 on: January 22, 2015, 08:51:08 pm »
That is slick!!!
Offline FlatBlack77
« Reply #424 on: January 22, 2015, 10:24:10 pm »
neato burrito man
Offline the dan
« Reply #425 on: February 18, 2015, 09:21:24 pm »
So idk if i mentioned that i went with the 4 position accuair E-level air ride controls for my truck but:
I took of my upper control arms and used a ball end mill on one of the original bosses for the C5, i didnt want to add any critical stress points but i needed a flat square spot for the heim.  Check out that clamping, they dont teach you that in tech school,
Machined the front brackets to hold the potentiometer. had to get nifty with the Auto X feed and using the Y by hand to make a contour of the C5 Arm mount.
And then i machined some spacers that act as miss alignment for the heims as well as correct geometry for the arms
Machined the rear accuair mounts
Offline LTZ C20
« Reply #426 on: February 18, 2015, 09:39:24 pm »
Very nice work
LTZ Cheyenne C20
Offline Shifty
  • I bleed Bowtie red...
« Reply #427 on: February 19, 2015, 11:31:24 am »
Ye gad that's some beautiful work... 8)
98 C2500 ext cab longbed
Offline the dan
« Reply #428 on: February 19, 2015, 02:12:06 pm »
Thanks guys, pulling the motor tonight to do some supercharger work and install the melling oil pump, as well as the innovators west crank balancer/pulley and index the trans. supposedly they say I don't have to but my uncle proved them wrong
Offline the dan
« Reply #429 on: February 25, 2015, 01:06:11 am »
Accuair in the rear is done
motor came out, high volume oil pump, some cosmetics, a new power steering bracket to accomodate the new pulley, 8 rib innovators west crank pulley, and final fitting the supercharger
« Reply #430 on: February 25, 2015, 06:06:43 pm »
Looks awesome!
Offline FlatBlack77
« Reply #431 on: February 25, 2015, 10:21:42 pm »
work of art
Offline the dan
« Reply #432 on: June 19, 2015, 11:41:13 am »
been busy, trying to get it on the road by july 3rd so ive been working on it every night till 1am and I started a new job so im just burying myself alive.. anyways:
Grand Sport speedlines and tires!
Offline LTZ C20
« Reply #433 on: June 19, 2015, 01:56:12 pm »
Looks great.
LTZ Cheyenne C20
Offline outlaw70nova
« Reply #434 on: June 19, 2015, 04:02:51 pm »
Absolutely beautiful!
