Author Topic: 83 c10 re-innovated Pro Touring  (Read 516855 times)
Re: 83 c10 re-innovated, air ride
« Reply #390 on: April 12, 2014, 07:29:33 am »
So I noticed you welded in the cross member over the motor. So what happens if the motor goes and you need to pull it? Guess it isn't a big deal to cut and weld it back in place though when the time comes.
      It is not the easiest to see but the cross bar (over engine) I believe comes out, look closer at these 2 pics.
Offline tex62
  • Lurker
« Reply #391 on: April 12, 2014, 08:01:33 am »
Yes sir I missed it completely. Good eye!
87 chevy suburban. 350 tbi w/ 700r4. 2wd sluggish tank sporting plastidip paint.
Offline the dan
« Reply #392 on: July 12, 2014, 12:58:32 am »
So rust bullet sucks, more so the etch meathod i believe, paint didnt adhere to the metal
cleaned the heads up, matched, valve seals, and a little casting clean, along with new springs
ARP'd out the 6.0l
milled the lifter valley cover flat so it didnt look so crappy
cleaned and painted the oil pan, glass bead the motor mounts
Shortened up the dip stick
made my throwout bearing -3an and extended the bleeder
as she sits
other than the paint lifting i did all of that yesterday/last night. i used my strike of motivation
Offline the dan
« Reply #393 on: July 12, 2014, 01:01:13 am »
This truck is so cool.
sorry i havent been at a computer lately, generally dealing with iphones for interenet.
yes its removable as stated. its kinda hidden, pretty fun part to make
« Reply #394 on: July 12, 2014, 09:31:44 am »
     At least you got some time to work on your truck.
     My honey do list just keeps getting bigger.  Gotta say though, wife is gone all next week for work, wife gone = any extra time I get not at work will be on truck.
« Reply #395 on: July 15, 2014, 05:30:59 pm »
Awesome!
Offline the dan
« Reply #396 on: August 07, 2014, 12:41:34 am »
Polished the tank
got some work done tonight let me tell you...
tucked the wires
« Reply #397 on: August 08, 2014, 07:23:24 pm »
     Those spark plug wires will be fun to change.
Offline the dan
« Reply #398 on: August 13, 2014, 11:12:51 am »
Not at all. Finishing making them is going to be the hard part
Offline the dan
« Reply #399 on: September 03, 2014, 06:51:02 pm »
 finished assembling my accessories, also made my steam port cross over for the heads and fit it to the waterpump
Offline FlatBlack77
« Reply #400 on: September 03, 2014, 10:31:14 pm »
MOAR
Offline the dan
« Reply #401 on: September 15, 2014, 08:44:46 pm »
MOAR
Your wish is my demand (?)
Finished up my fuel rails and injectors, wired them up and hid the wires
Finished my power steering feed line
And then since my tensioner isn't going to work, I purchased a new one
Paxton Novi 2000, a little bigger than I wanted but the price was right, should be pulling it off his corvette in a week or two
« Reply #402 on: September 16, 2014, 08:42:48 am »
     Actually after seeing put together, it makes more sense now.  That truck is going to be a work of art when you are done.
« Reply #403 on: September 16, 2014, 07:38:05 pm »
It already is!
Offline frotosride
    • WFO CONCEPTS
« Reply #404 on: September 16, 2014, 09:38:06 pm »
It already is!
Biggest understatement I've seen yet!! how in the world are you able to d all this and afford to school at the same time?.. Keep it coming!
