Shift points
Topic: Shift points (Read 12518 times)
greenmonster
Shift points
December 22, 2007, 09:48:57 pm »
At full throttle my truck shifts 3500-3800 rpm is this normal.I reved the motor in park and it can hit 6000rpm at about 6200-6300 I think the valves started to float.
zieg85
Re: Shift points
December 22, 2007, 10:13:40 pm »
My '08 Escape Company Car shifts at 6000 from first to second when it is wound up tight.
76_Scottsdale
I'd rather push my Chevy than drive a Ford
Re: Shift points
December 22, 2007, 10:45:11 pm »
Sounds ok to me. Any higher then that it feels the motors gonna tear outta the hood. Are you wanting a higher shift point?
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
greenmonster
Re: Shift points
December 22, 2007, 11:21:05 pm »
It seems to me that there is alot of motor left.I figered i should use it.I would like for it to shift at 4500 rpm.Idon't want to push it past 5000rpm even though Igot it to hit 6000rpm. It has a weiand stelth intake,holley carb,mild cam and duel exhaust with flowmaster 40's.
76_Scottsdale
Re: Shift points
December 22, 2007, 11:25:25 pm »
I would suggest getting a shift kit installed then. They're only about 50 bucks but it's about 150 to have it installed in the vehicle. You can alter the shift points and it also make them more solid. Be careful on free-reving the motor, It's a good way to float a valve and smoke it. It's not just how high your motor will rev, it's how high it will rev safely.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
greenmonster
Re: Shift points
December 22, 2007, 11:29:13 pm »
IT has a shift kit in it i didn,t put in in it was in there when i bought the truck.When it shifts in to second it will brake the tires lose.
76_Scottsdale
Re: Shift points
December 22, 2007, 11:39:16 pm »
If it's breaking the tires loose shifting to second, then I don't know what more you could want
If it's already got a shift kit then IDK
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
greenmonster
Re: Shift points
December 22, 2007, 11:44:09 pm »
another thing it that it won't kick down out of third gear above 40mph is that normal
greenmonster
Re: Shift points
December 23, 2007, 12:01:18 am »
thanx for the help 76 talk to you later.
FlatBlack77
Cheap Fast Reliable - Pick 2
Re: Shift points
December 23, 2007, 12:52:28 am »
when I had my stock 400 small block in my truck when I first got it it had a shift kit that had just recently been installed along with a tranny rebuild. at full throttle it would rev to about five grand and chirp the tires every shift. 3800 sounds really low.
76_Scottsdale
Re: Shift points
December 26, 2007, 01:43:59 am »
If your tranny doesn't wanna shift out of 3rd above 40 I would check to see if your kickdown cable is installed properly.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
Re: Shift points
December 26, 2007, 09:00:06 am »
What transmission do you have? If you have an early shift (not including the TH400) adjust the TV cable tighter. If you have a TH400 replace the modulator with an adjustable one and check your detent solenoid.
⌠ŻŻŻŻŻ' [☼===☼]
greenmonster
Re: Shift points
December 26, 2007, 08:04:28 pm »
I have 350 trans.I adjusted the cable by releasing the clip and opening the throttle all the way and pushing the clip back in.Is there another way to do it or some sort of trick you could tell me.THANKS for the help it is alot easier getting things fix with you guys and GIRLS on this site.
Re: Shift points
December 26, 2007, 09:40:54 pm »
You went the wrong way with your cable. Depress the tab and push the pluger towards the firewall. Then depress the throttle WOT (engine off) and that's your base adjustment.
⌠ŻŻŻŻŻ' [☼===☼]
greenmonster
Re: Shift points
December 26, 2007, 09:52:47 pm »
I don't understand what you said.AT full throttle I can still pull the cable out 1/2 inch,is that to much.
Shift points
