Author Topic: Work to date this winter on my 79 K 30  (Read 14069 times)
« on: December 27, 2007, 10:33:33 am »
Well so far this winter I have had a rear outer wheel bearing let go and mow the stub. Built it back up with weld filed it down to fit a new bearing, new inner, outer, and new seal. New rear u joint on rear shaft. Tail light wiring repairs, one new light assembly, and new 7 prong trailer plug. New front tires, brake pads, one caliper retainer clip, and bolt. New heater core and heater hoses ( at 5:00 AM in the middle of plowing my route. ) Then last night the same axle seal let go was up till 3:00 this morning fixing that. Plus the typical stuff on the plow and sander, and general maintenace etc.
 Gotta love the plow business!
Offline ccz145a
Re: Work to date this winter on my 79 K 30
« Reply #1 on: December 27, 2007, 10:37:54 am »
What's the old saying... "Make hay while the sun shines". Gotta do what you gotta do. Keep it going, Blazin.
« Reply #2 on: December 27, 2007, 11:08:55 am »
At least you are replacing stuff because it is getting used :D.  I am replacing stuff on something that isn't even running yet.
Offline JJSZABO
« Reply #3 on: December 27, 2007, 11:33:22 am »
So am I... :P
Jeff
86 Chevy C-10
350, TH400
« Reply #4 on: December 27, 2007, 08:00:02 pm »
Guess what? I posted this, left to get sand and go sand some calls. Not my normal customers but they call and wanted sand, they either do it themselves or their plow guy only plows. Anyway I got about a 1/4 mile from the pit and it felt like the transfer case popped into neutral. I tried shifting it back in but it was already in 2x. I looked in my mirror and the inside dual was about 3" out past the side of my body!!!
The outer wheel bearing gave it up. I spent most of the day with a buddies help fixing that on the side of the road, while it was snowing!!!!!!!!!!!!!!!!
Offline jonkmbll89
« Reply #5 on: December 27, 2007, 08:03:42 pm »
Sounds like your haying all the fun. ;D
« Reply #6 on: December 28, 2007, 10:24:46 am »
Well my theory is that there is crap built up in the bottom of the axle tube. Preventing the oil getting out to the bearings. So for a cave man fix to get me through the next few days because we just had snow last night, supposed to get more tomorrow night and Sun. into Mon. too. Any way I am going to drill a hole in the cover, add about a half quart of oil, plug it with silicone, and hope she holds until we have a week of good weather. I am going to swap the whole rearend as both spindles are kinda boogered up now.
« Reply #7 on: December 29, 2007, 01:20:00 pm »
That stinks!  Side of the road repairs are bad enough and then you have Snow!  YUK!
« Reply #8 on: December 29, 2007, 02:30:23 pm »
I took it apart last night, got it back together around 11:00 PM. Since everything got chewed up in there I seamed to forget when we did the road side fix there is supposed to be a big washer between the nut, and the bearing! DER. Well for a washer because I wasn't about to walk through thigh deep snow and then tear another rearend apart top get one. I had an extra nut so I ground the threads out of it and ground it to about half its thickness! So I still got to cave man something. We shall see how well it holds up. Have a lead on a couple rearends to swap it out.
« Reply #9 on: January 02, 2008, 01:07:15 pm »
Well I can add new front springs to the list. Heard a clunking noise near the end of my route. Got home started looking things over, left front main leaf snapped in half right behind the u bolt plate!
Offline 123 pugsy
« Reply #10 on: January 02, 2008, 06:52:34 pm »
You just can't win! :'(
Pugsy
76 C10 LWB
TPI 350
Offline JJSZABO
« Reply #11 on: January 02, 2008, 07:10:23 pm »
When it rains........or in your case snows
That suxs
Jeff
86 Chevy C-10
350, TH400
« Reply #12 on: January 02, 2008, 08:30:29 pm »
I guess I cant expect much more from an antique truck!!! I plow 38 driveways. 2 of them are over an 1/8 mile long. 3 are small apt. 3 and 4 family unit places.
 A guy in town I know works at a spring shop. I just got home from his house. New 4 leaf front packs, new u bolts, all new hardware, shackles, and upper shackle bushings. list just shy of $600 his / my cost $370.
« Reply #13 on: January 02, 2008, 08:46:18 pm »
SWEET!!!!  That Antique has probably paid for itself several times...
« Reply #14 on: January 02, 2008, 08:52:21 pm »
Blazin you need a parts truck man!
