Author Topic: 700R4 Pump Ears  (Read 4941 times)
Offline aort07
700R4 Pump Ears
« on: January 01, 2008, 08:03:27 pm »
I pulled the transmission out tonight and found the ears were broken on the pump. What can I do to fix this? Can I put new ears on it and how?
Re: 700R4 Pump Ears
« Reply #1 on: January 01, 2008, 08:16:17 pm »
Replace the pump and converter. i promise you if you just put in a new pump gear it will break again. I've seen this 100's of times. When the sun gear cracks the housing will warp. Just get a reman pump and a new converter if it's been damaged. Go with a 13 vane pump
Offline aort07
Re: 700R4 Pump Ears
« Reply #2 on: January 01, 2008, 09:24:42 pm »
This transmission has less than 4,000 miles on it off a rebuild. I got it from a respectable shop in Florida that has the 13 vane pump and all. It had a hardened sun gear and everything put in it. It didn't do a thing to the converter. I will call the guy that built it tomorrow and see what he says. Thanks for the advice.
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
Re: 700R4 Pump Ears
« Reply #3 on: January 02, 2008, 01:02:52 am »
If the pump went then there will be junk in the converter. You will need a new one.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline aort07
Re: 700R4 Pump Ears
« Reply #4 on: January 02, 2008, 10:55:47 am »
Wouldn't there be metal in the fluid? There was none, it was still nice and bright red like it was new.
Offline werewolfx13
Re: 700R4 Pump Ears
« Reply #5 on: January 02, 2008, 02:11:30 pm »
Not necessarily, there can still be junk in the converter that you wouldn't see without slicing open the converter. You could try to use it, but theres a very good chance it will destroy the new pump.
Chris
'83 Chevy c10 Silverado SWB
