Author Topic: brakes!!!  (Read 7572 times)
Offline gpday08
brakes!!!
« on: January 03, 2008, 01:34:15 pm »
where can i get rear disc conversion kits for my '79 c10??? any help is appreciated!!
Offline eventhorizon66
Re: brakes!!!
« Reply #1 on: January 03, 2008, 03:49:40 pm »
Here's a kit from Stainless Steel Brakes Corp.  Rear Standard Disc Brake Kit  I've heard that unless you tow heavy loads, rear disc brakes on a truck don't offer much additional braking performance.  Still tempted to try them myself, though.
Also your proportioning valve should be converted over to the disc/disc type.  Or you could get an adjustable valve.
'85 C10 SWB 350 700R4 TKO600
Offline werewolfx13
Re: brakes!!!
« Reply #2 on: January 03, 2008, 06:07:18 pm »
I would strongly encourage the use of a master cylinder designed for rear disk brakes as well..Drum MCs keep a little bit of pressure on the rear brakes, to keep the shoes closer to the drums. Using the drum MC will cause your rear brakes to drag a little bit.
Chris
'83 Chevy c10 Silverado SWB
Offline JJSZABO
Re: brakes!!!
« Reply #3 on: January 03, 2008, 06:10:09 pm »
Also need to use a different proportioning valve.
Jeff
86 Chevy C-10
350, TH400
Offline xtremjeepn
Re: brakes!!!
« Reply #4 on: January 03, 2008, 06:46:11 pm »
Lots of information on rear disc swaps on Coloradok5.com. Lots of the 4x4 guys do these swaps.
I am in the middle of putting rear discs on my 1 ton crew cab. Using DIY4X.com rear caliper brackets, 77 Eldorado e-brake calipers, 3/4 ton front rotors. FWIW I have about $400 in the set up with ALL brand new parts.  MUCH less than some of the kits.
« Last Edit: January 03, 2008, 06:48:42 pm by xtremjeepn »
Cole
Restomod Crew Cab Short box on 37"s
Re: brakes!!!
« Reply #5 on: January 03, 2008, 06:53:08 pm »
Offline gpday08
Re: brakes!!!
« Reply #6 on: January 08, 2008, 01:18:34 pm »
THANKS GUYS
Offline xtremjeepn
Re: brakes!!!
« Reply #7 on: January 08, 2008, 01:29:36 pm »
(Here is mine just to add some thing to the tread) I got the DIY4x.com brackets on the truck.  Just for reference these are Eldorado calipers, 3/4ton front discs and DIY4x.com brackets.  I still have to make all the lines.
I also got the Detroit Locker in. Looks like we may have a working rear axle again soon.
Couple of quick pics for fun.
Cole
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
Re: brakes!!!
« Reply #8 on: January 08, 2008, 09:48:05 pm »
That is the same exact jack I have extemjeepn...good to know that it can support a 4x4! I was concerned about it's ability to hold up my lowered 74.
Offline xtremjeepn
Re: brakes!!!
« Reply #9 on: January 08, 2008, 11:16:53 pm »
Haha, I have had that little jack for a LOOOOONG time. Still works, but to be fair there is no bed, rear bumper, exhaust on that truck right now. ;D
Cole
