Author Topic: single to dual headlight  (Read 23317 times)
Offline dwg30
« on: January 03, 2008, 02:28:32 pm »
I have an '86 3/4 4x4 that has single headlights and was wanting to change to the dual headlights. I know what parts I need as far as core support, headlight cans, etc. but was wondering on the wiring. Haven't looked at my wiring to the lights yet but is there a pigtail that can be changed or will I have to rewire them or get another harness?
Re: single to dual headlight
« Reply #1 on: January 03, 2008, 04:07:02 pm »
You will need the whole under hood body wire harness from the firewall plug out to the lights.
Offline ccz145a
« Reply #2 on: January 03, 2008, 04:12:21 pm »
I have a complete unmolested '84 dual headlight harness if you are interested.
Offline DrPepper1010
« Reply #3 on: January 15, 2008, 03:16:39 pm »
I changed from 2 to 4 headlights on my 82. All I did was get the high beam lamp connector from a donor truck. Then spliced the green wire, from the connector, to the existing green wire and the black wire, from the connector, to the existing black wire and everything works fine. I did the splice back under the plastic wire loom so no one can see the splice.
BTW, I have a 4 headlight core support that's in very good condition. I'll sell it to you for $30. If you live close, you can pick it up. Email me if your interested.
Offline Stewart G Griffin
« Reply #4 on: January 15, 2008, 04:03:40 pm »
How do you switch from 4 to 2?
« Reply #5 on: January 15, 2008, 04:15:46 pm »
with a baseball bat ;)
Actually I have the 2 headlight setup from an 89 burban if anyone is interested,
Offline Dragon
« Reply #6 on: January 15, 2008, 05:44:04 pm »
Simplest anwser would have been for you and dwg30 to have swapped Headlight harnesses, but since he probably already replaced/spliced his, you could pick up an upgraded(Thicker Gauge Wire Etc.) harness for an early '80's Truck from  ...
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline JJSZABO
« Reply #7 on: January 15, 2008, 06:47:28 pm »
Jeff
86 Chevy C-10
350, TH400
Offline jonkmbll89
« Reply #8 on: January 15, 2008, 07:49:08 pm »
« Reply #9 on: January 16, 2008, 12:24:21 pm »
Unless I'm missing something, switching from 4 lamps to 2 lamps electrically, requires no work. You just plug the dual element wire/plug into the new dual element head lamp. The wire/plug that used to plug into the high beam lamp doesn't need to be plugged into anything. Just tie them back so the wires don't short out. Switching the rad support, head lamp buckets, etc. requires a little more work.
