Author Topic: ban me and Being Cold  (Read 11917 times)
Offline VeeTwin60
« on: January 03, 2008, 08:55:03 pm »
Okay, I am going to try to kill 2 questions with one thread:
1986 Chevy C-10 350/350 - Holley 650cfm w/man choke
1. It has been colder than the proverbial well-digger's butt here in the south the last couple of days.  Since the low temps have moved in, my truck will not idle correctly - even after being completely warmed up.  It drives just fine... just idle.  I've heard Holley's are temperamental when it comes to ambient temp.  Do I need to make some adjustment while the cold is set in?
2. Here comes the ban me part.  My fuel gauge needle is floppy.  When the tank is full, it is fine.  But when it drops to about 3/4 to 5/8 of a tank, the needle does the hokey-pokey - sometimes even dropping down to "E" and then going back and forth - depending on whether I'm accelerating, stopping, turning, etc.  Is there a fix for this?
Thank you guys.  I look forward to getting to know all of my fellow Chevy truck owners.
1986 C-10 1/2 TON 2WD SWB
Re: ban me and Being Cold
« Reply #1 on: January 03, 2008, 09:00:56 pm »
Sounds like you have a bad sending unit in the tank.
What do you mean it won't idle correctly? too high too low?
Offline monte85
« Reply #2 on: January 03, 2008, 11:58:23 pm »
my gas guage does the same thing and i have a new sending unit. i think it all has to do with the way the tanks are mounted and the length of the tank. the fuel has so much room to move around when the level gets off full, the sending unit and the guage can't keep up with the changing levels.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
Offline Redneckchevy
    • Photo Bucket
« Reply #3 on: January 04, 2008, 12:42:38 am »
My Gage dont do that...If there is a 1/4 it stays...If its full it stays at full..and i have a heavy foot..But hey my truck was built in Canada..And we all no There is nothing better then being built in Canada lol
Offline JJSZABO
« Reply #4 on: January 04, 2008, 09:23:16 am »
Alright, you started it.....
Canada is the only county with hockey players on the money - what's up with that? :D :D
Jeff
86 Chevy C-10
350, TH400
Offline VeeTwin60
« Reply #5 on: January 04, 2008, 07:12:41 pm »
It idles rough.  For instance, sitting at a light, it shakes the truck sometimes as it idles roughly.
« Reply #6 on: January 04, 2008, 08:03:10 pm »
check your float setting
Offline jonkmbll89
« Reply #7 on: January 04, 2008, 08:50:02 pm »
I changed out my sinding unit out twice in my Blazer and the gage still jumps. I think it is the fuel gage itself.
Offline okuma
« Reply #8 on: January 05, 2008, 04:08:29 am »
it i sthe fuel gage! replaced it an problem solved.
« Reply #9 on: January 05, 2008, 08:01:51 am »
If it's a faulty gauge or printed circuit it will typically swing towards Full or over full... To go towards E resistance needs to drop which is typically a shorted winding in the sender or the wire going to the gauge grounding on the frame. Check it before you start changing parts.
Offline okuma
« Reply #10 on: January 08, 2008, 10:12:51 pm »
well ville you might be right but.... my swinging gage "E-F and F-E" was replaced and this was the solution for mine.
Offline chevy754x4
« Reply #11 on: January 08, 2008, 10:34:44 pm »
My '75 with the small fuel gauge does the same "hokey pokey" thing on both tanks and I'm pretty sure it's the gauge also unless both sending units went goofy at the same time
Offline Fordeatinz71
  • 78k miles and counting
« Reply #12 on: January 08, 2008, 10:46:24 pm »
well, then every GM fuel gauge i've ever seen is bad.  i've never seen a GM truck fuel gauge from '99-down that DIDN'T swing around.  i mean, they don't go all the way from full to empty (if that's what you are talking about i insert foot now...) but they DO float around.  the ONLY time mine doesn't float around is if it's CRAMMED full or DEAD empty.  actually, that's like my low fuel "light" when it's on E and it's still floating a little, i know i have some time left...if it's not floating, i'm about to be dead in the water  ;D
Offline werewolfx13
« Reply #13 on: January 09, 2008, 12:09:22 am »
I use the floating needle the same way with mine..I haven't been able to afford to put more than half a tank in it at a time for over a month, so the only time its ever dead still, I better be within 1/4 mile of a gas station.. ;D
Chris
'83 Chevy c10 Silverado SWB
« Reply #14 on: January 09, 2008, 12:19:04 am »
heck yea, the gas prices are eating me alive.  well, along with my truck's various issues...like no OD or lockup TC...and my "auto-locking" hubs that won't unlock, so my front driveline is perma-engaged...
can't wait until tax time when i get the 350 installed, along with a new 700R4 and manual locking hubs...along with a few other goodies... ;D
