Author Topic: rearend ?'s  (Read 9389 times)
Offline The Beast
rearend ?'s
« on: January 04, 2008, 01:59:38 pm »
ok i have a 78 c10 short wide. i belive i have 2.73 gears but i dunno i want to have a locker put in by a shop and was looking at a gear type rather the clutch type. anyways im having trouble figuring out what rear end i have (10 bolt, 12, or 14) as well as axel spline count. i just want to order the locker with maybe some 3.73 gears and get a shop to install it for me. or if anyone in the seattle, washington area that can recomend a shop to do the work for me. i work in a performance shop but i dont feel like doing the work on my own truck right now lol.
78" short wide rat rod
Re: rearend ?'s
« Reply #1 on: January 04, 2008, 03:46:35 pm »
IF it is original, it will have a 12bolt axle in it with 28 spline count.
Offline The Beast
Re: rearend ?'s
« Reply #2 on: January 04, 2008, 10:25:40 pm »
great thanks for the help, then i can look on the option card on the glove box to see what thrice of alphanumerical for the rear end gears?
Re: rearend ?'s
« Reply #3 on: January 05, 2008, 06:43:02 am »
It might not be on the option card. SOme of them just say standard rear end ratio. As far as 10, 12 or 14 bolt. Duck under the back of the truck, & count the bolts.
Offline The Beast
Re: rearend ?'s
« Reply #4 on: January 05, 2008, 04:20:20 pm »
i didn't think it was that simple for findout out what diff i got lol. and what about the old trick of jacking up the back marking locations and turning a axel and count the revolutions until they remeet?
« Last Edit: January 05, 2008, 05:33:58 pm by Captkaos »
Offline werewolfx13
Re: rearend ?'s
« Reply #5 on: January 05, 2008, 06:44:35 pm »
It works, its not precise, but it gets you close enough to estimate.
Chris
'83 Chevy c10 Silverado SWB
Offline SUX2BU99
Re: rearend ?'s
« Reply #6 on: January 07, 2008, 04:23:01 pm »
Somewhere around Seattle is Randy's Ring and Pinion. One of the best well known shops for rear end parts in the aftermarket. Do a web search, I'm sure they'll pop up.
Re: rearend ?'s
« Reply #7 on: January 07, 2008, 04:27:14 pm »
http://www.randysringandpinion.com  I highly recommend them...  I get everything from them and never got anything sent that was incorrect.
Offline The Beast
Re: rearend ?'s
« Reply #8 on: January 08, 2008, 05:27:41 pm »
cool thanks for the help everyone.
Offline Fordeatinz71
  • 78k miles and counting
Re: rearend ?'s
« Reply #9 on: January 08, 2008, 11:03:53 pm »
man, i'm ducking in late here, but if it's a standard LD 1/2 ton, it should have a good 'ol 10-bolt in it.  and yea, most likely with 2.73 or 2.76 gears.  find your gearing code and get it on here and i'll help ya figure out exactly what it is...
Offline 1976Scottsdale
Re: rearend ?'s
« Reply #10 on: January 09, 2008, 02:40:14 pm »
Yeah, being a 78, it would have a factory 12 bolt and most likely either a 2.73/76 or 3.07 axle ratio.
Offline The Beast
Re: rearend ?'s
« Reply #11 on: January 09, 2008, 04:45:45 pm »
ya i ran the rpo codes months ago and i thin it came up as 2.73's, and its a 12 bolt. so in a few months its going to the shop for new axels, locker, and 3.73's
Re: rearend ?'s
« Reply #12 on: January 09, 2008, 05:07:55 pm »
I think late 81 was when they started using the 10 bolt
Re: rearend ?'s
« Reply #13 on: January 09, 2008, 05:09:44 pm »
Yep, started in mid 81 and was phased out by 1982.
Re: rearend ?'s
« Reply #14 on: January 10, 2008, 09:45:20 pm »
yea, i realized after doing some reading that the 12-bolt should be in his truck...i was gonna edit my post but ya'll replied beforehand.  anyway, the 10-bolt was used for longer than a year i think.  i had a '79 that i KNOW had a 10-bolt (had to rebuild it) and my '83 has 10-bolts at both ends...my '89 also had a 10-bolt rear...so did my '90...
