Author Topic: Hazard flasher issue.  (Read 6244 times)
Offline 81C10
« on: January 06, 2008, 11:50:37 am »
73 GMC C15. The other day when I used the flashers on the side of the road, they wouldn't turn off (the switch went back in but they kept flashing). So I pulled the relay(?) (round thing with 2 tabs in an L shape) and they stopped flashing, but I also had no turn signals. today I pulled the turn/flash fuse and they flashed when I put the relay back in and the turn signals still don't work. I really don't want to pull the steering column apart. What can I do? I don't care if the flashers work as long as I have turn signals. Also, I took the screw out of the flasher switch that holds the knob on and the switch fell down somewhere, not I have an empty hold in the sterring column.
'73 GMC C15 307 3 on the tree
'81 GMC C15 5.7 Diesel TH350 (doesn't run yet)
'82 K10 6.2 Diesel TH350 (daily driver)
'84 K20HD 383 TH400
Re: Hazard flasher issue.
« Reply #1 on: January 06, 2008, 11:54:17 am »
You need to take your steering wheel off and check the switch.
Offline 81C10
« Reply #2 on: January 06, 2008, 05:05:43 pm »
Thats done- its apart, hazard switch appears to be gone. Turn signals are working again. I was going to put it back together but the lockplate won't slide far enough down the steering shaft. It slid off with no problem. Any ideas?
'84 K20HD 383 TH400
Offline Bitzer!
  • Smiles per gallon
« Reply #3 on: January 06, 2008, 05:46:29 pm »
sorry to slightly hijack the thread! I've got the opposite. Fixed my hazzard lights/switch but turn signals have never worked. I'm gonna replace both relays due to corrosion at the terminals but how would you test the switch is working?
cheers
1979 GMC CrewCab  C20 1t
« Reply #4 on: January 06, 2008, 08:49:06 pm »
Did you take the retaining ring off? The lockplate is also desinged only go on one way. You don't have it on upside down do you?
Quote
Insert Quote
Do they light up but just not blink? Elaborate some more.
Offline 81C10
« Reply #5 on: January 06, 2008, 10:08:34 pm »
Yes I took the retainging ring off. I don't think It was backwards.
'84 K20HD 383 TH400
Offline Bitzer!
  • Smiles per gallon
« Reply #6 on: January 07, 2008, 01:58:04 am »
Quote
Insert Quote
nothing at all- they all light up on the 4way but nothing side to side!
