Author Topic: Electric Help turn Signals  (Read 7888 times)
Offline Bitzer!
  • Smiles per gallon
« on: January 15, 2008, 12:40:26 pm »
Hi guys, in the process of re-wiring the turn signals & 4way etc due to previous owner having spaghetti hands and only red wire by the looks and it all melted in to one mess.
could someone tell me what colour wire goes into the switch (via flasher can) and which colour for left turn and which for right? I have a new switch with the correct connections etc
The 4way I'll have to wire differently from you guys!!
cheers
Bitzer
1979 GMC CrewCab  C20 1t
Re: Electric Help turn Signals
« Reply #1 on: January 15, 2008, 12:45:46 pm »
what year is your truck?
Offline Bitzer!
  • Smiles per gallon
« Reply #2 on: January 15, 2008, 12:53:32 pm »
the majority is a '78 we think!  From the black connecting block we have:
black  \
            both going to bottom of switch
pink    /
black
light blue
dark blue
brown/grey
purple
yellow
green
white
cheers m8- help! out of all these i only need to know which is power to switch and left/right out!
Offline Bowtie Bomber
  • Rolling American Iron
« Reply #3 on: January 15, 2008, 09:43:15 pm »
I know for sure yellow is your turn signals.. I forgot what the rest where. I'll go piddle around on my truck tommaro and figure it out. I'm having problems with my tails lights as well.
My truck is my flying fortress, the road is my sky, and Toyota's are the enemy bunkers that need a busting.
Offline Bitzer!
  • Smiles per gallon
« Reply #4 on: January 16, 2008, 03:48:07 am »
thanks guys- any help really appreciated
Offline Bitzer!
  • Smiles per gallon
« Reply #5 on: January 28, 2008, 03:27:10 pm »
Sorry to bring this one up again but.................
Ok- the 4way works and flashes as it should do.
The left and right turn signals flash a couple of times then stay on. If I turn it all off for a few minutes they work and then stay on again.
The switch and flasher can is new, so is most of the wiring. Is it a dodgy flasher can or in the wiring that I haven't touched yet?
cheers
Bitzer
« Reply #6 on: January 28, 2008, 04:00:59 pm »
swap the turn signal flasher with the 4 way flasher and see what happens
Offline Bitzer!
  • Smiles per gallon
« Reply #7 on: January 28, 2008, 04:14:56 pm »
wont be able to get to it until the weekend now :-\    so fed up with Mr Spaghetti hands!
Vile- what would the original colour wire be used for earth/ground?
cheers
« Reply #8 on: January 28, 2008, 04:20:00 pm »
Ground should be Black.
Offline Bitzer!
  • Smiles per gallon
« Reply #9 on: January 28, 2008, 04:22:58 pm »
Phew glad I asked!! UK cars new and old use brown!!
« Reply #10 on: January 28, 2008, 05:53:33 pm »
Did you happen to look at the schematic for your truck?
Guess the image is too big
Here's the link http://www.autozone.com/images/cds/gif/large/0900823d801129cb.gif
« Last Edit: January 28, 2008, 06:01:48 pm by VileZambonie »
Offline Bitzer!
  • Smiles per gallon
« Reply #11 on: January 29, 2008, 04:22:11 am »
Vile yr a diamond! Looks like i can get it sorted from the diagram! is the  "schematic" the diagram? never come across that one b4!
I'm guessing you guys use "hot" as a perminant live? just checking to be on the safe side!!
cheers
« Reply #12 on: January 29, 2008, 06:34:35 am »
cheers
No that's Paris Hilton  ;D Yes hot at all times means battery voltage, hot in run means when the ignition is switched on. Schematic meaning electrical diagram.
Offline Bitzer!
  • Smiles per gallon
« Reply #13 on: January 29, 2008, 06:42:40 am »
Hot / Diamond = Paris Hilton? !! are you sure!!
