Author Topic: prostreet 4-link  (Read 9531 times)
Offline low79fx
prostreet 4-link
« on: January 18, 2008, 07:59:27 pm »
Need help with a Chassisworks prostreet 4-link.Has anyone ever installed one of these setups? Does any one have specs for this setup?Saw cubicdollars posted he had one,does anyone know if he's still a member?
« Last Edit: January 18, 2008, 08:10:24 pm by low79fx »
Offline cubicdollars
Re: prostreet 4-link
« Reply #1 on: January 18, 2008, 08:48:51 pm »
I just replied to your PM but if anyone else is interested here is the artical I used.  http://www.cachassisworks.com/Stories/HowCAC-009_WEB.pdf
Good Luck
Offline low79fx
« Reply #2 on: January 20, 2008, 08:59:56 pm »
It does help,I had already ran accross this article,it is very informative.But I was wondering if you could give me the tube length mearsurements.I am fabricating a kit similar to the one installed.Need length of top and bottom tubes from edge of tube to center hole of bushing at welded rodend.Please reply!!!Thanks low79fx
« Reply #3 on: March 23, 2008, 09:39:12 am »
Any updates on you 4 link install ?
« Reply #4 on: March 23, 2008, 09:43:17 am »
cubic how did yours turn out? Where did you buy your set up from? Did you ever make a post here on it? I can't remember. I'll be doing mine down the road but am considering air ride
« Reply #5 on: March 23, 2008, 09:04:20 pm »
Hey Villa I have had my 4 link in for over 10 years but as soon as the dually is done I am going to get back on my stepside. I am looking for a 9" ford rear end with disk brakes to Narrow. I already have a set of 15 X 12 convo Pro's for it. Here are a couple of picts.
Offline HAULIN IT
« Reply #6 on: March 23, 2008, 09:37:47 pm »
Cubic, I see your hunting a 9" & disc brakes. The ideal set-up I feel if your wanting to match the GM truck front bolt pattern is this: Get any 9" housing, Get the rear brake set-up off of a '90's Caprice/Impala, When you have the housing done buy the ends that except the 3.150 bearing w/ the GM car backing plate pattern, The axleshafts will have to have a 1/4" longer "set-out" to match the GM distance, The wheel bolt pattern is the same as the trucks & you get modern brakes for a vehicle of similar weight & you can buy parts at any local store. They have the built-in drum inside for the E-brake. Just a thought, Lorne
« Reply #7 on: March 23, 2008, 09:53:52 pm »
Thanks For the info I think I know where there is a junked out caprice  ;D
Offline jonkmbll89
« Reply #8 on: March 24, 2008, 09:47:04 pm »
That is a clean bed, you did a good job on the wood work. ;D
Offline low79fx
« Reply #9 on: May 09, 2008, 05:46:45 pm »
Hey guys,want to post some pics but don't know how? Can some one help?
Offline low79fx
« Reply #10 on: May 09, 2008, 06:03:48 pm »
check this out, all fabbed at home , with exeption of coilovers.
« Last Edit: May 30, 2008, 07:56:43 pm by low79fx »
