General Discussion
Aftermarket Fans
Topic: Aftermarket Fans (Read 4963 times)
Redneckchevy
Aftermarket Fans
January 20, 2008, 02:42:23 pm »
What would be the benefit of a After market cooling fan? like one of them 70$ ones from summit?
Cpl degrees cooler then stock or is it just for looks?
Re: Aftermarket Fans
January 20, 2008, 03:15:41 pm »
The main benefit is thermal efficiency/consistency and lack of mechanical drag on the crankshaft. Unfortunately the only real bolt on high efficiency fans for our trucks are around $500 bucks. A 16" fan alone with no shroud will not proved adequate cooling
Redneckchevy
January 20, 2008, 03:35:58 pm »
well i found one..Fits perfect in the shroud in place of the old one guy wants 15 bucks for it like new condition not warped or nothing
jonkmbll89
85 Chevy Silverado C10 swb 5.7/350
January 20, 2008, 03:44:13 pm »
Sounds like a good deal. I would love to put a dual setup on my 85 c10, but like Vile said they are pricey.
January 20, 2008, 04:51:19 pm »
If you can mount one effectively inside your existing shroud then go for it! Just make sure you wire it up using the correct gauge wire, circuit protection, and a relay controlled by a thermostatic switch.
86swb
Born a Chevy man
February 01, 2008, 08:19:32 pm »
$15.00, I say go for it. Just make sure it does work.
'86 swb Siverado
'84 lwb Silverado (low miles)
1931 Model A 2-Door Sedan
(in family since new)
I just gave the '31 to my Grandson
General Discussion
Aftermarket Fans
