Author Topic: Cooling fans  (Read 4089 times)
Offline Redneckchevy
    • Photo Bucket
Cooling fans
« on: January 21, 2008, 11:39:52 pm »
Just wanting some input....Flex fan with no clutch or stock fan with clutch?
Got a Electric fan for my chevy...And was thinking about replacing my other trucks stock with the Flex fan from the chevy....Now i got the chevy with the flex fan..so i dont no if it robs power or gives power...What do you guys think? ???
Offline JJSZABO
Re: Cooling fans
« Reply #1 on: January 22, 2008, 07:22:08 am »
Flex fans can come apart and do some real damage.  Search the web on flex fans to see what I mean.  I do not like flex fans.  Either go with regular fan with clutch or electric fans.
Jeff
86 Chevy C-10
350, TH400
Re: Cooling fans
« Reply #2 on: January 22, 2008, 09:44:23 am »
The stock fan with a clutch is MUCH better, cools better and uses less power...
    • Photo Bucket
Re: Cooling fans
« Reply #3 on: January 22, 2008, 10:57:04 am »
Vile...What do you say about your fan on the 454?
Re: Cooling fans
« Reply #4 on: January 22, 2008, 12:40:36 pm »
Older flex fans were very prone to cracking and flying apart. When I first put my posi in my 74 years ago I went to do a burnout and all of a sudden BOOM and the truck started shaking like CRAZY! I quickly shut it off and opened the hood. The fan had sent a blade through the schroud, through both layers of the steel hood and the blade landed in the middle of main street about 150 feet away. Prior to that I was under the hood reving it up. Luckily it didn't take my head off.  :o Flex fans are much better quality now and work very well but can be noisy. They provide less drag which you will notice right away if you have a heavy clutch fan hanging on the front of your water pump now. The downside like I said is they can be a lot noisier than your clutch fan. Don't ever use an old flex fan and if you've had one on your truck for a few years, periodically check it for loose blades or cracks around the rivets.
On my 74 for now I have a flexfan until I decide exactly what I'm going to do for an electric fan... I drew up a schematic for someone on here a while back to give you an idea of how easy it is to wire one up.
