All Classified forums require a Site Supporter subscription. It is only $25 per year and you can buy and sell whatever you like on the forum. To become a Site Supporter, go to Your Profile and select "Paid Subscriptions."
OOoooo, sorry about that! I was just lookin at that link again and noticed the springs were the same for all those models. I made the mistake of thinkin they had it setup for individual models. My apalogies. Thanks Chris for pointin that out.
Do you know the weight of the front end? If not, do you have a local scale that will allow you to get front / rear axle weights? This can be done at the track too if there is a scale. Weigh the truck, then just the rear of it. But it would be prefered if you were in it."Drag springs" are simply long springs with a low spring rate. The reason they are set up this way is to store energy. The more preload on the spring, the more stored energy you have. Then you can use the shock to tune the rate at which the front rises.Spring rate is the amount of weight it take to compress a spring 1" So a 300lb spring that is 10" long, would be 8" long with 600lbs on it and 6” long with 1200lbs.The trick is to compress the spring as far as possible with out inducing coil bind and leaving a little room for upward travel IE hitting a bump in the road.You can determine coil bind simply. You can either call the spring MFG and ask them what compressed height is or, measure one coil with a caliper, count total coils and do a little math. Now I like to add a little wiggle room here and add one extra coil. IE if you have 12 coils, do the math like you have 13. ( 0.47” * 13 = 6.11 compressed height).Control arms induce a leverage ratio. That can be figured out fairly easily by taking a measurement from the ball joint location to the LCA shaft that the arm swings on. Then take a measurement to the center of the spring location from the control arm shaft. Divide the spring number in to the LCA. This is what's known as leverage ratio.. (stock stuff on my 63... 9 / 17.25 = 1.91) I would assume this to be the same through the early 70’s but double check.Now this is where things get a little tricky. You have a 14.5” 350lb spring with a compressed height of 7.3” and you need to now if this will work. It’s all going to depend on unsprung weight.This is weight of:WheelsTiresBrake assemblySpindleBearings1/2 of the following partsUpper control armLower control armAll tie rod endsSprings (but then divided again by leverage ratio)Shocks (but then divided again by Shock ratio)Sway bar end linksTake your total front axle weight and subtract the unsprung weight. Divide that by two. Multiply that by the leverage ratio. This is the weight the spring needs to support.2,260 Front weight200 Unsprung weight2060 is the sprung weight1130 is each sideMultiplied by your leverage ratio 1.91 = 2,165That would compress the spring a total of 6.18” making the spring 8.32” at ride height. Leaving .98” of travel before coil bind.This is about where my truck is. I have about 2” of preload on the spring before the truck is lowered to ride height.It’s a lot to figure out the right spring. But if you new the static weight of the front of your truck I could probably ball park a spring for you.Here is a little spread sheet I threw together some time ago trying to figure out what will work for me.http://73-ls1.com/63truck/weight_sheet_revision_2.xlsSome things that need to be know about this sheet..1) Red Areas should be left alone..2) This is currently set up for my trucks rear suspension. There might have to be some slight changes to the equations depending on your suspension set up (IE 3 link it won't compute the UCA for the rear properly). It takes the individual weights of the control arms and then doubles them in the final eqution showing unsprung weight. It should work however for a 4 bar, 4 link, truck arm, Ladder bar ect. It also uses a panhard bar in the equation so a ladder bar with a Z bar or a watts link set up might need the adjustments as well.3) The front suspension equations are bases on a double A-arm suspension. So a strut set up might not work right or it might if you leave the UCA weight out.4) If the drive shaft weight looks funny, ignore it. I divided it by 1/4 but it is multiplied by 2 in the final equation. So it does represent 50% of it's total weight.5) "Max Control Arm Drop From Ride Height" is the amount the spindle would fall before maxing out suspension travel jacking up the front end (hope that made sense)..6) All mesurements in the sheet are guesses right now. I have some weighing to do.7) Axle centerline has to do with the truck arm suspension. The LCA goes past the rear axle center line so I tried to figure out the actual unspring weight by adding that in there. You'll more than likely put that to 0.
I HATE the fiberglass hoods...make sure you check out some light weight steel hood options. they fit better and look better imo
