Author Topic: which carb for my mild 305?  (Read 3746 times)
Offline jo3y1nf4nt3
  • '86 swb....since high school 1996, '66 nova SS HT
« on: January 24, 2008, 12:21:18 pm »
it's .030 over L69 (H.O.!!!!!)  with a mild crane cam (not sure of specs right now) with a performer rpm intake, 1.6 roller tips, ~9-9.5:1 compression.  edelbrock site says the 1403 (500 cfm, electric, non-egr) is for 305 and smaller....i had the 1406 (600 cfm, electric, non-egr) and it was ok...maybe too big?  i dont' know what kind of vacuum it was pulling, but it was average.  all my stuff worked...
and since i'm on the the mic, i installed my motor already...without the distributor...do i ahve to take it out to install the distributor...i think i made an uh-oh....
and another question..since i am using the 1.6 roller tip rockers, do i have to use longer lenght pushrods or is std. ok?  the valves are the same (stock from L69..what is that? 1.84/1.5)  thanks guys...joey.
jo3y in baytizzle (baytown y'all!)
"if only i could soothe my hunger by rubbing my belly" - diogenes
Re: which carb for my mild 305?
« Reply #1 on: January 24, 2008, 12:51:58 pm »
The dist. can be installed after the motor is in assuming it is in the standard position.
Offline jo3y1nf4nt3
« Reply #2 on: January 24, 2008, 12:54:32 pm »
standard meaning?? lol...upside down comes to mind??
« Reply #3 on: January 24, 2008, 01:47:09 pm »
jo3y1nf4nt3 Can't you come up with a better avatar then boogers and plaque?
Yes you can install the distributor and remove it with the engine in.
standard pushrods will work
