Engine/Drivetrain
oil leaking on starter and oil filter
Topic: oil leaking on starter and oil filter (Read 7524 times)
the_legend_1981
January 27, 2008, 08:31:38 pm »
where could this be coming from i dont think its the rear main seal its dry back there 1980 gmc newre 350 crate motor
Fordeatinz71
78k miles and counting
Re: oil leaking on starter and oil filter
January 27, 2008, 08:33:33 pm »
most likely valve cover...or intake manifold...possibly oil pressure sending unit...
1983 GMC Sierra K1500 SWB-sold
the_legend_1981
January 28, 2008, 06:54:58 pm »
could it posably be the gasket for the distributsor?
January 28, 2008, 07:05:31 pm »
It could be lots of things. Retorque your valve covers and intake manifold bolts (in sequence) wipe everything down and run it. If you still can't pinpoint it put in some dye tracer and use a UV light to pinpoint the origin. Autozone sells those little Uv lights for a few bucks.
86 chevy silverado
January 28, 2008, 07:06:47 pm »
Those are the four hot spots for small blocks to leak, check them all. Might have to get in the tighter areas with a small mirror and light. Also see Viles advice.
Last Edit: January 28, 2008, 07:08:20 pm by 86 chevy silverado
werewolfx13
Site Supporters
January 28, 2008, 11:11:13 pm »
I second everything everyone here has said..my motor leaks an obscene amount..I've confirmed leaks in the rear main, pan gasket front and rear, V/C gaskets (even retorqued), and intake manifold gaskets (also retorqued, still leaks there)..My transmission also leaks fluid from the rear seal (and the fluid slowly runs down the drive shaft and scatters on the undercarriage)... I've got so much petroleum based liquid on the undercarriage of my truck I shouldn't have to worry about floorpan or bed floor rust for the next decade, or until I swap motors and degrease everything.
Chris
'83 Chevy c10 Silverado SWB
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
January 29, 2008, 12:03:17 pm »
Quote
You forgot to mention whether your power steering pump/lines leak---why stop with oil and tranny fluid?
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
werewolfx13
Site Supporters
January 29, 2008, 01:30:48 pm »
Actually, my PS lines are wet around the clamps, but I check the fluid every time I change the oil..well..every time I change the filter and refill the oil anyway..the oil leaks fast enough to change itself atleast once before the next scheduled oil change..and I've never had to add any fluid
Chris
Engine/Drivetrain
