Author Topic: that rust converter stuff  (Read 10195 times)
Offline 87swb
« on: January 28, 2008, 08:16:08 pm »
as most of ya'll know i have that rust problem on my truck. today i sanded it down the best i could and put some of that rust converter stuff on it that comes in that little white bottle you buy at auto-zone. they say that's what does the trick on rust. it said on the bottle it turns rust into primer. can someone enlighten me?
Offline okuma
Re: that rust converter stuff
« Reply #1 on: January 28, 2008, 08:28:23 pm »
well this turns the rust into a black acid-burnt appearance.     i have use some rust killlers before and they are alright i guess.
Offline JJSZABO
« Reply #2 on: January 29, 2008, 07:40:19 am »
Most of those coatings convert rust (iron oxide) into an inert black oxide.  I've used it in areas where I will not epoxy.  The material data sheet for my epoxy says not to apply over rust converter.  This is the stuff I've used with good results: http://www.eastwoodco.com/jump.jsp?itemID=15974&itemType=PRODUCT&path=1%2C2%2C389%2C390&KickerID=347&KICKER
Jeff
86 Chevy C-10
350, TH400
« Reply #3 on: January 29, 2008, 08:30:42 am »
Similar to Naval Jelly. Loctite, Permatex makes it too
Offline 87swb
« Reply #4 on: January 29, 2008, 09:47:45 am »
ok, sounded like a gimmic, but as long as it gets the rust off
Offline ccz145a
« Reply #5 on: January 29, 2008, 10:26:56 am »
You have to nuetralize it after your done. the acid does not just go away. a white residue will come through your paint if you dont, at least, that's what happened to me.
Offline JJSZABO
« Reply #6 on: January 29, 2008, 11:16:52 am »
Eastwood's rust converter, converts rust to black oxide - it does not get the rust off, it converts it.  NO Neutralizing required.  Just mix, spread and let dry.  That's why I picked it.
I am not getting paid to advertise for Eastwood, but I have used this and it works as described.  I used it on my frame with the rust encapsulator and chasis black.
« Last Edit: January 29, 2008, 11:21:24 am by JJSZABO »
Jeff
86 Chevy C-10
350, TH400
