General Discussion
Igntion source
Topic: Igntion source (Read 4002 times)
Redneckchevy
Igntion source
January 29, 2008, 12:36:28 pm »
Ok..Looking to install something that requires me to tap into a ignition source...Since i dont like splicing wires and so on...Can i plug in ware it says ign?
Last Edit: January 29, 2008, 12:39:24 pm by Redneckchevy
Re: Igntion source
January 29, 2008, 01:02:58 pm »
The ING's above the SHUNT is where you want to tap into.
Redneckchevy
Re: Igntion source
January 29, 2008, 01:06:09 pm »
Thank u very much
and also is there a place on there that i can tap into my Gage lights? or will i have to use tap connector and piggy back the wire?
Last Edit: January 29, 2008, 01:07:46 pm by Redneckchevy
Re: Igntion source
January 29, 2008, 01:41:59 pm »
You should be able to see B+ with a test light at the LPS when you turn on the parking lamps.
General Discussion
Igntion source
