Author Topic: Side Molding Screws  (Read 6228 times)
Offline unbludictable
  • Low Down Blu
Side Molding Screws
« on: January 29, 2008, 02:32:24 pm »
How do I get these darn side molding screws off?
Re: Side Molding Screws
« Reply #1 on: January 29, 2008, 03:27:53 pm »
Which ones?  The ones on the side of the truck?  Phillips head screws..
  • Low Down Blu
« Reply #2 on: January 29, 2008, 03:57:46 pm »
No, the one that hold the side molding on. They have a clip on the outside and they go all along the side of the truck.
« Reply #3 on: January 29, 2008, 05:06:27 pm »
Those shouldn't be screwed on. The Molding attaches to the clip which is retained to the body. Can you post a pic of the style moulding you have since there were som many variations?
« Reply #4 on: January 29, 2008, 05:20:48 pm »
Are you removing the molding from the truck or the clips from the body?
Offline Dragon
« Reply #5 on: January 29, 2008, 05:59:38 pm »
Any area of the truck with trim that has an easy to access point behind the trim mounting(Wheel Wells/Lamp Pockets/Etc) has these type of mounting trim studs with nuts on the back
In the Areas that can't be easily accessed from behind, has trim Studs either Welded or Riveted to the body(Ie Back of Cab/Etc), and the only way to remove those is by grinding the heads off with a Cut-off wheel....
Behind Cab, and Sometimes along the top side of the bed..
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
  • Low Down Blu
« Reply #6 on: January 30, 2008, 11:52:04 am »
I'm removing clips and the screw that's holding it, but before i take a grinder to it, just wanted to know!
I'm new at this!!
