Author Topic: Stalling in reverse  (Read 4333 times)
Offline euromade
Stalling in reverse
« on: January 30, 2008, 10:53:49 am »
I have a funny issue with my 87 5.0 TBI.  When I put it in reverse it stalls on me, every time, unless I play with the gas pedal.  When in D i have absolutelly no issue!  It starts fine, it idles fine, it does not stall on me when I stop at a red light.
Any ideas.  I'd like to use this thing to tow my boat, but with this stalling issue it would be almost impossible to use it at a boat ramp.
Thanks,
New parts installed in the past month or so:
- Fuel filter
- air filter
- plugs and wires
- fuel pump/sending unit.
Offline Redneckchevy
    • Photo Bucket
Re: Stalling in reverse
« Reply #1 on: January 30, 2008, 11:05:20 am »
check ur vacuum lines
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
« Reply #2 on: January 30, 2008, 09:16:38 pm »
i'm assuming he has a 700r4 so he doesn't have vacuum lines that control the tranny but check all the vacuum lines on/around the motor to make sure you don't have a leak
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
« Reply #3 on: January 30, 2008, 09:34:47 pm »
Check the throttle body base gasket. With the engine idling mist some carb claean at the base of the throttle body and see if the engine speed changes.
Offline DnStClr
« Reply #4 on: February 02, 2008, 11:02:23 am »
If you don't lose rpms at a stop light the timing is probably ok. When was the tranny fluid changed last? A tranny shop can tell you if you have a bad torque converter. I would expect it to have low power and  hesitation problems with a vacuum leak.
Don
87 Chevy Silverado
