Author Topic: removing the emblem off the fender  (Read 8084 times)
Offline plowking_90
« on: February 01, 2008, 05:03:22 pm »
how do i go about doing this with out tearing up the fender or breaking the emblem?
Offline plowking_90
Re: removing the emblem off the fender
« Reply #1 on: February 01, 2008, 05:04:06 pm »
its a 1977 gmc camper special, and also how do i remove the camper special emblems on the cab?
Offline hotrod24
« Reply #2 on: February 01, 2008, 05:56:58 pm »
well you should be able to go behide the seat and put your hand up a hole in the cab and you should feel a couple of nuts
« Last Edit: February 01, 2008, 05:59:31 pm by hotrod24 »
1978 pontiac grand prix...
Offline HAULIN IT
« Reply #3 on: February 01, 2008, 06:23:53 pm »
Plowking, Really the only way, is to remove the fender. The emblems were put on the fenders & then installed on the trucks. It has been years since I've had any reason to remove them without the fender, I usually took a putty knife & slid under them & smacked it with a hammer,breaking the studs off & buying a new emblem & putting it on with barrel clips. I do believe the back nuts can be had from the door jamb with the door off if it didn't have the foam seal & I believe we could get the front one on the left side with some tool from under the hood (with allot of swearing) but the right one was a no-go. I hope this helps, it's been about 20 years since I did one that way, so I might be all wet. I would just remove the fender, it's not that hard & less stressful & you will also do a better job painting. Lorne
« Reply #4 on: February 01, 2008, 06:54:25 pm »
If you want to keep the ones on the fender intact, I HIGHLY suggest removing the fender to remove it.  You can't get to it unless you have some REALLY small hands and long arms
« Reply #5 on: February 01, 2008, 07:24:39 pm »
Just 2 speed nuts hold them on.
Offline plowking_90
« Reply #6 on: February 01, 2008, 08:20:35 pm »
i only need to change one fender so the one im changing will be a piece of cake but the other one when i go to paint it i want to take it off so i dont get paint on it, it seems imposible to mask off
« Reply #7 on: February 02, 2008, 11:59:48 am »
you can mask it.  Just be patient.
