Author Topic: transfercase shifter  (Read 16637 times)
Offline plowking_90
« on: February 02, 2008, 08:36:27 pm »
i got a transfercase shifter off of a turbo 350 and i have a turbo 400 the one off the 350 has 2 arms to switch gears and the 400 only has 1 what do i do? and can i make it work
Re: transfercase shifter
« Reply #1 on: February 02, 2008, 08:39:00 pm »
Neither of those are a transfercase. What do you mean? ???
Offline plowking_90
« Reply #2 on: February 03, 2008, 07:01:08 am »
im not sure on what transfercase i have but the shifter i got has 2 arms on it to shift the transfercase but my transfercase only has 1
« Reply #3 on: February 03, 2008, 08:13:55 am »
I'm not following what you are trying to do. If you already have the right shifter for your transfercase why do you want to change it? You need to elaborate on what you are trying to do if anyone can help you. To ID your transfercase look at the tag on the backside of it. Example NP208
« Reply #4 on: February 03, 2008, 11:45:56 am »
To clarify! A Turbo 350, & Turbo 400 are transmissions, not transfercases. Our trucks were offered with a NP 203, 205, & 208 transfer cases. NP meaning New Process
(1) we should know the year of your truck, or drivetrain / frame if its had a body swap?
(2) we should know which transfer case you have. There is a tag on the back of the t case with one of the formentioned numbers on it.
(3) What exactly are you tying to accomplish?
(4) How did you end up with missmatched parts?
If the part doesn't fit you most likely are not going to make it work or if you did it would be allot more hassle than just going and getting the right parts!
« Last Edit: February 04, 2008, 07:38:26 am by Blazin »
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
« Reply #5 on: February 03, 2008, 11:58:28 am »
I concur!
Offline plowking_90
« Reply #6 on: February 08, 2008, 05:38:41 pm »
it is a np 208 with 261 gear ratio, i dont know what kind of shifter it takes but i have one and it has 2 arms to shift it and my transfercase has 1 can someone help me
second of all is the np 208 a good transfercase? my truck is an offroad truck with 6 inches of lift and 36 inch super swampers
« Reply #7 on: February 09, 2008, 08:12:05 am »
A 208 is fine as long as you don't wail the crap out of your truck. I have broken them clean in two pieces before in a plow truck. The 208 has a t case shifter that lays almost flat down against the floor when in 2 wheel drive and stands almost strait up when in 4 lo. It has an adjustable linkage rod that connects to a flattish plate via a cotter pin type set up. The plate slips over the shift rod on the transfer case via a shaped to corespond to the shift rod and is held in place by a nut. I am not sure what you have but it is not going to work with a 208 if it has two rods. Go to the scrap yard and get the right shifter, shifter mount, and interior shifter cover.
Offline plowking_90
« Reply #8 on: February 09, 2008, 09:12:07 am »
what year does th np 208 belong in my truck is a 1980 gmc?
« Reply #9 on: February 09, 2008, 07:12:50 pm »
Not quite sure what your asking there?
 I have never seen and 80 with a NP 208. I might be wrong but I am pretty sure 81 was the first year. All 208s all use the same shifter.
Offline plowking_90
« Reply #10 on: February 09, 2008, 08:13:05 pm »
when i bought my truck it has so many miss matched parts i want to get everything back to normal so i can find parts for it, my truck is a 1980 gmc 1/2 ton the transfercase is a np 208 i cant find a shifter for this transfercase i might have to look on a 81-87 chevy truck
« Reply #11 on: February 10, 2008, 05:18:07 pm »
Yep.
Offline autorepr
« Reply #12 on: February 12, 2008, 02:16:23 pm »
It sounds like you have a 203 transfercase shifter your wanting to use on your 208 case. I don't think it's going to work.
1 rod switches the 203 from Hi to Lo and the other rod shifts it from Loc to Reg 4 wheel drive.
Keep looking for a 208 shifter.
