Author Topic: downshift cable  (Read 4729 times)
Offline mikewb
downshift cable
« on: February 04, 2008, 08:40:16 pm »
anybody know how and what to the cable hooks to on a edelbrock carburetor
Offline muddnutz
Re: downshift cable
« Reply #1 on: February 10, 2008, 12:20:42 pm »
  YOU HAVE TO BUY THE ATTACHMENT EXTRA  A SMALL STUD THAT GOES IN THE BOTTOM HOLE .  ABOUT 5-8$
Offline mikewb
Re: downshift cable
« Reply #2 on: February 10, 2008, 04:49:04 pm »
if it doesnt work. is there something to fix. or is it broke inside the trans?
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
Re: downshift cable
« Reply #3 on: February 10, 2008, 06:13:39 pm »
If you have the stud from them for our trucks (GM kickdown cable adapter in Edelbrock package) and you hooked it up and it didn't function correctly, it probaby just needs to be adjusted.
Offline mikewb
Re: downshift cable
« Reply #4 on: February 11, 2008, 03:19:45 pm »
its adjusted far back as goes but it still wont kick down
Re: downshift cable
« Reply #5 on: February 11, 2008, 05:31:29 pm »
What transmission do you have? If you disconnect it from the carb is there spring tension on it when you pull it?
Offline mikewb
Re: downshift cable
« Reply #6 on: February 11, 2008, 05:35:37 pm »
th350 and yeah it has tension. it hasnt ever been hooked up. i hooked it up the other day and it doesnt work. i didnt know if it not being used ruins it
