Author Topic: Where else can I put my oil sender?  (Read 4509 times)
Offline gmiles
« on: February 05, 2008, 08:43:38 pm »
I have a 74 Stepside with a 305 in it. I have an HEI dist. and am installing Dakota Digital gauges. The oil sender for the guages is made by VDO and is HUGE. Can I put  the oil sender someplace else besides the back of the engine by the distributor? There's a small plug just above the oil filter on the block. Can I remove the plug and put the sender there?
thnx
Grady
Re: Where else can I put my oil sender?
« Reply #1 on: February 05, 2008, 08:48:34 pm »
You can however you can just run a brass tee or elbow at the back of the engine for the sender. That's how they did it from the factory. similar to this but longer
Offline JJSZABO
« Reply #2 on: February 05, 2008, 08:53:05 pm »
That's what I used with another small adapter to get it away from the HEI dist.  I also have the Dakota gauges.
How do you seal the pipe threads and maintain ground (-) and keep it from leaking oil?
Jeff
86 Chevy C-10
350, TH400
« Reply #3 on: February 05, 2008, 08:56:29 pm »
 As long as you don't drop more than 300mv on the negative side you'll be fine. If you use teflon tape no more than 3 turns or use liquid teflon which is even better.
Offline gmiles
« Reply #4 on: February 05, 2008, 09:48:45 pm »
Thanks Vile ;)
