4 Wheel Drives
Hard shifting 205
Topic: Hard shifting 205 (Read 8438 times)
Blazin
Blazin new trails!
Hard shifting 205
February 12, 2008, 10:25:29 am »
My new K30 has an issue with the 205 case. More often than not it is a bear to shift out of 4 wheel high into 2 wheel. Once in a while it shifts out real nice and smooth. When this happens i end up shifting all the way into 4 lo or neutral because I am used to it being hard to shift. It shifts in to lo fine smooth as silk. As for shifting into 4 high it works perfect. Have had it shift out so hard a few times I have to give it the old kick with my right heal. The other thing i have noticed is there is only about a 1/2" between being in 4 high and neutral. Also when its in 2 wheel it rattles almost sounds like its grinding against 4 high a bit.
Any ideas? Thanks Harold.
Re: Hard shifting 205
February 12, 2008, 10:59:32 am »
Try rolling it backwards when it is hard to shift. Since it is a geared case they usually bind some...
Blazin
Blazin new trails!
February 12, 2008, 03:12:28 pm »
I do that it is easier but still a pain in the _ _ _ to move it.
February 12, 2008, 05:09:50 pm »
I would change the fluid making sure you have the right fluid in it too and lube up the linkage with some of your weasel pee
⌠ŻŻŻŻŻ' [☼===☼]
Blazin
Blazin new trails!
February 28, 2008, 10:35:08 pm »
Well I took the bolt out, not rusty or dry I greased the fitting again, second time. Sprayed it with weasel pee. still shifts hard most times. once in a while it shifts right out. Coarse I am expecting it to be hard so i go right past 2 hi and into neutral or 4 lo! Still have to put my heel to it once in a while.
77c15
combustion=suck, squeeze, bang, blow
February 29, 2008, 06:26:13 am »
Weasel pee?
Blazin
Blazin new trails!
February 29, 2008, 08:51:44 am »
PB Blaster, WD40, Break Away. or any other type of penetrating oil.
Monzter
March 13, 2008, 09:53:06 am »
The 205s are real sensitive to get out of 4wd back into 2wd when your on pavement or even hard packed dirt, it causes the drivetrain to bind up. If your done wheeling when your trying to get it out of 4wd try unlocking the front axle's hubs & move the truck back & forth to relive the binding in the drivetrain.
http://www.monzterkuztomz.com/
http://www.myspace.com/monzter_kuztomz
Bubba13
March 13, 2008, 02:16:28 pm »
I had about the same problem with my 203. I tore it down to find a brass perforated thrust washer had failed. It was extremely hard to get it out of 4 low.
Watch where you're going, remember where you've been...
hotrod24
March 13, 2008, 03:59:57 pm »
where do you oil it at
1978 pontiac grand prix...
Blazin
Blazin new trails!
March 13, 2008, 09:14:35 pm »
I have had many 205s over the years. Only had one other one that shifted hard, but not this hard. It seems to be coming into it now that I have shifted it out of 4 hi a crap load of times with my heel. If it breaks then I will know what the problem is.
I am not going to get out and unlock and re lock my hubs at all 32 of my driveways plus when I need to shift it into 4 hi to make a hill on the road!
Right where it bolts on to the adapter. Mine and all the 205's I have had in the past has a grease fitting right there.
Last Edit: March 13, 2008, 09:17:23 pm by Blazin
76PasoGMC
June 01, 2008, 02:24:41 am »
synthetic gear lube
Blazin
Blazin new trails!
June 01, 2008, 06:49:57 am »
Shes coming into it more and more as I use it. Course now winter is over the truck won't get use but maybe once a week if that!
4 Wheel Drives
Hard shifting 205
