Author Topic: how to lower  (Read 12065 times)
Offline hogwild
how to lower
« on: February 12, 2008, 10:48:39 pm »
i wasnt going to lower my truck but after looking and thinking , i have desided to do a small drop. what is the easiest way to lower it about an inch to 1 1/2 " front and maybe 2 inches in the back?  and opinions on this to please. heres the truck
1986 sb 406 ci
2003 mud buggy 1300 hp 528
if my wife askes it was only fifteen bucks
Re: how to lower
« Reply #1 on: February 13, 2008, 04:40:33 am »
2" lowering spindles and 2" lowering shackles
Offline FlatBlack77
Re: how to lower
« Reply #2 on: February 13, 2008, 09:18:47 am »
That is a good lookin truck ya got there. You are right on lowering it, it kinda looks like a four wheel drive the way it sits up. as said above some spindles and shackles would to the trick
Offline hogwild
Re: how to lower
« Reply #3 on: February 13, 2008, 08:02:19 pm »
what about cutting front coils and axel flip.opinions
1986 sb 406 ci
Offline Pushrod
Re: how to lower
« Reply #4 on: February 13, 2008, 09:53:13 pm »
Go for it. You've already got that truck goin in the right direction as far as looks go. A flip kit and bringin the front down about 5 or 6 inches too would give it a good stance to go along with where the bodys headed.
Junkie 77 Stepside AKA "The Sanford Machine"
81 Malibu 350 and a 4 speed
Re: how to lower
« Reply #5 on: February 14, 2008, 10:01:43 am »
You don't really want to get more than about 2" of drop with cut coils, the ride starts deteriorating after that point.  A flip will give you about 5-6" drop, so if you only did the cut coils and flip the rear would be lower than the front...
Offline hogwild
Re: how to lower
« Reply #6 on: February 17, 2008, 10:57:44 pm »
weres the best place to buy the spindels and shackels ? . gon this far now i mite as well do it write. how much are they worth?
1986 sb 406 ci
Re: how to lower
« Reply #7 on: February 18, 2008, 09:25:09 am »
I can get you a 2.5/4" drop kit for $425 + shipping.
Offline SUX2BU99
Re: how to lower
« Reply #8 on: February 18, 2008, 04:56:02 pm »
I found some Bell 2" drop spindles at a local shop that they wanted a reasonable price for. $200 I think it was. Guy said a customer bought them but they wouldn't fit due to him having a 1" thick rotor whereas those particular spindles only fit trucks with the 1 1/4" thick rotor. What's that all about?
Re: how to lower
« Reply #9 on: February 18, 2008, 05:03:26 pm »
The heavy duty brakes had thicker rotors. I don't see why he couldn't just get new rotors.
Offline 80stepsideguy
Re: how to lower
« Reply #10 on: February 19, 2008, 03:06:40 am »
I say buy them, the 1.25 inch rotors you can get from summit for like 75.00 a piece and you can use your stock calipers.
thanks
pat
1998 Chevy 1500 S/B 2wd
Re: how to lower
« Reply #11 on: February 19, 2008, 09:47:44 am »
You can get 1.25" rotors from any parts store for about $50...   I wouldn't let it stop me from getting them.
Offline ccz145a
Re: how to lower
« Reply #12 on: February 19, 2008, 10:45:50 am »
if you don't have them yet, you'll need the wider calipers as well.
Re: how to lower
« Reply #13 on: February 19, 2008, 01:27:21 pm »
Thanks Chip, I thought someone mentioned that...  You will need the HD calipers...
Offline Pushrod
Re: how to lower
« Reply #14 on: February 20, 2008, 01:54:00 pm »
Summit, Bell Tech, DJM, or ebay. Spindles can ocasionally be cheap on ebay or you could spend 150-300 on a new set. Shackles are pretty cheap - less than $50 in most cases. I'd say add a set of hangers to the mix. You can get a set of shackles and hangers for less than 200.
