Author Topic: brake..........questions or concerns  (Read 18779 times)
Offline monte85
« on: February 13, 2008, 11:21:29 am »
well heres the problem and i don't know if you other guys out there have had similar problems or not. i have an 87 v20 with the jb7 brakes( over 8500 gvwr). i have the proportioning valve above my rear axle. anyways, when it rains, the brakes will lock up everytime you push the pedal. also the pedal gets real sensitive(alittle pressure will put you through the windshield). this has occured since i bought the truck. i asked my uncle who has dealt with gm stuff for most of his life about it and he said it was common for those trucks(whether he meant the larger 3/4 and 1 tons or all from this vintage i don't know). before i start getting responses, let me say that it does not do this at any other time, just when it rains or there has been alot of moisture in the air. everything in the braking system is also new with the exeption of the master cylinder. i put in all new lines front to back, wheel cylinders, calipers, and hoses. and bled the crap out of everything. i don't mind it really, i was just wondering if there is a way to get rid of it. i never seem to see any of the newbies asking about it either. anyway, if someone out there can shed some light on this, i would appreciate it.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
Re: brake..........questions or concerns
« Reply #1 on: February 13, 2008, 11:48:45 am »
The rear piece only adds pressure when there is a load on the truck that is what the lever is for.
As for it locking the tires in the rain, how hard are you laying into it?  It will DEFINITELY be different than a ABS equipped truck and they are light on the rear when you lay into them.  Are you only complaining about it during rain?
How tight are the rear shoes adjusted?
Offline monte85
« Reply #2 on: February 13, 2008, 12:21:31 pm »
i never expected it to feel like abs. i've never owned an abs equipped vehilcle. i'm not putting alot of pressure on the pedal either. only enough to slow the truck down under normal conditions(like if you came up on a car traveling alittle slower than you were), but they lock up during wet conditions. i guess i should be more clear about my feelings here. i'm not complaining about it(although it does kinda sound like it). if its the way it is then its the way it is. i've lived with it for almost 4 years now and i just know that the truck will do it. i was just wondering if anyone else has had the same experience. up here in connecticut its raining like crazy now and its done it to me since the rain started. the rears aren't tight. when you spin the tires you might here them rub in a spot or two as the drum spins.
Offline Redneckchevy
    • Photo Bucket
« Reply #3 on: February 13, 2008, 12:58:41 pm »
Well what i do when it rains or i go thur a puddle i ride my brake a lil at low speeds to heat them up...And When stoping in wet condtions its always best to lightly pump ur brakes....insted of using steady pressure try to use 3 light pressure pulses insted of  just one long one.....But this advice should only be taken if ur sure u have no leaks and nothing is broke...
« Last Edit: February 13, 2008, 01:21:02 pm by Redneckchevy »
Offline monte85
« Reply #4 on: February 13, 2008, 01:33:42 pm »
Redneck - if i pumped them 3 times this is what would happen. i would hit my head on the windhield 3 times.
heres an example: in the parking lot at work here, there is space in front of the buildings and that meets up to a main driveway. i'll back out of a space and drive to the main driveway. only going about 5 or 10 mph for less than a minute. i'll apply light easy pedal pressure to slow down for the main driveway. this is enough to make the wheels lock. when they lock, i don't go skidding off sideways, its nice and straight. like if both sides lock.
Offline JRConnieK10
« Reply #5 on: February 13, 2008, 02:04:39 pm »
Spoken like a true truck driver. lol.
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
    • Photo Bucket
« Reply #6 on: February 13, 2008, 02:13:43 pm »
man that sounds crazy...... u might wanna let some slack out of them read adujsters and make sure ur wheel cylinder isnt leaking......cause from what ur saying it sounds like the back is locking up way before the front do....
« Reply #7 on: February 13, 2008, 02:24:33 pm »
That is WAY to touchy, the rear prop may be bad, but with only 10mph and light pressure the rears shouldn't lock up.
Offline monte85
« Reply #8 on: February 13, 2008, 02:41:07 pm »
well i don't actually know if it is the rears that are locking or fronts. i just know when it happens i hear tires skidding on pavement. and both wheel cylinders are new. where would you even get one of those rear proportioning valves anyway? and if they were adjusted to tight, why would it only do it when it rained?
and i'm guessing from all this talk that this was not a common quirk with these trucks.
« Reply #9 on: February 13, 2008, 04:35:03 pm »
1st thing you need to do is pull your drums. Inspect to make sure you have a primary and secondary shoe on each side and that they are installed correctly. The front shoe will have less meat on it than the rear shoe. There should be no axle grease or brake fluid on the linings. Make sure the shoes are sitting flush on the anchor pin. If they are not someone adjusted the parking brake cable too tight or the parking brake is hanging up. Now once all of that is ok adjust the brakes so there is slight drag on them. Then see what happens, if they still lock, disconnect the arm on the rear proportioning valve and manually move it to see if it makes a difference. If the truck has been lifted you will need to correct for it. If it doesn't make it better then just bypass it.
Offline Dragon
« Reply #10 on: February 13, 2008, 06:20:05 pm »
Chances are your fronts are locking up and dragging, by the time the rears come to a stop... My truck does this too on slightly damp pavement, otherwise hope you have your seatbelt on when riding with me, cause it stops on a dime and will make change ;D  being that you are a Large Pickup, Honestly you should be giving yourself plenty of stopping distance between you and whatever is in front of you, reguardless of your brakes adjusted properly or not....
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
    • Photo Bucket
« Reply #11 on: February 13, 2008, 06:35:46 pm »
I get evil thought about what his truck is doing .wouldnt mind getting my father in law to go on a ride with me....Right when he starts running his mouth "pow" lol "sorry brakes are wet"
Offline JRConnieK10
« Reply #12 on: February 13, 2008, 08:25:01 pm »
Kinda oops, oh darn, he should have had his seat belt on. Yeah I can here it know honest honey it was an accident.lol.
BUILT NOT BOUGHT
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
« Reply #13 on: February 14, 2008, 07:51:24 am »
You guys should know that most brake shoes do this, no matter make or model, and especially if the shoes have ANY organic material in them. It is referred to as "swelling". Humidity in the air causes the shoes to swell and until they are heated up and the moisture cooked out of them, then you will likely kiss the windshield. I learned this in my 85 celebrity the hard way with no seat belt on just moving the car around in the yard.
Added-> You may want to look at replacing the shoes with some Raybestos or equivelant as they don't contain very much organic material at all.
« Last Edit: February 14, 2008, 07:53:48 am by 77c15 »
Offline monte85
« Reply #14 on: February 14, 2008, 09:18:03 pm »
i tried the thing that Redneck says he does. i rode the brakes a couple of seconds when i first started driving and it seems to stop them from locking up. thanks for all the help guys.
