Author Topic: which transfer case do I have?  (Read 5458 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: February 17, 2008, 07:03:09 pm »
84 K5 blazer. 700r4, auto locking hubs. Shift positions are 2hi, 4hi, n, 4 low, there is not a tag on the transfer case. If you can help me thanks in advance
Offline 86 chevy silverado
Re: which transfer case do I have?
« Reply #1 on: February 17, 2008, 07:13:39 pm »
NP208 I would have to guess, aluminum casing?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #2 on: February 17, 2008, 07:50:12 pm »
I just went out and checked with a magnet and its aluminum
« Reply #3 on: February 17, 2008, 08:04:06 pm »
You couldn't find a round tag on the rear output tailshaft area?
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #4 on: February 17, 2008, 08:15:58 pm »
I did not see any tag anywhere, I will have to double check. Is the np208 the least desirable between the np203, np205 and np208?
« Reply #5 on: February 17, 2008, 08:33:31 pm »
The 203 is full time cast case, least desirable because of the full time feature but a good case. The 205 is gear driven heavy duty cast case that most sought after for its strength, and the 208 aluminum housing chain driven which is most common and is also a good case, just not considered as strong as 205 because of aluminum housing and chain drive. Thats my view.
« Last Edit: February 17, 2008, 08:35:56 pm by 86 chevy silverado »
