Author Topic: door swap question  (Read 8677 times)
Offline robtco99
door swap question
« on: February 19, 2008, 01:01:37 pm »
Will the doors from a 73-87 regular cab interchange with the front doors on a 73-87 crew cab? Thanks
1979 K20 4X4 Camper Special
Re: door swap question
« Reply #1 on: February 19, 2008, 01:11:46 pm »
yep
« Reply #2 on: February 19, 2008, 01:21:32 pm »
Keep in mind you want these seperated into 73-76 and 77-91 versions
Offline Pushrod
« Reply #3 on: February 19, 2008, 02:47:09 pm »
How can you tell the difference between the two styles??
Junkie 77 Stepside AKA "The Sanford Machine"
81 Malibu 350 and a 4 speed
« Reply #4 on: February 19, 2008, 04:18:18 pm »
Easy,
This is a 73-76[/img]
This is a 77-91[/img]
Offline 82chevy
« Reply #5 on: February 19, 2008, 05:01:26 pm »
i picked up one of each used but in good shape for my truck recently not knowing they were different and im already having a hard time installing the glass and track in i think the older one. im using power windows so i think that makes a difference
« Reply #6 on: February 19, 2008, 05:45:17 pm »
no way will power motors go in the 73-76 doors (unless you hack the crap out of them) That is what the design change was for.
Offline Pushrod
« Reply #7 on: February 19, 2008, 06:03:55 pm »
Good tid bit of info there... Thanks!
Offline plowking_90
« Reply #8 on: February 19, 2008, 06:07:33 pm »
will 77 door pannels fit on 87 doors
Offline hotrod24
« Reply #9 on: February 19, 2008, 06:12:48 pm »
77 and 87 are mostly the same just the arm support is different
1978 pontiac grand prix...
« Reply #10 on: February 19, 2008, 06:21:39 pm »
I'll add that the earlier window regulator were shorter too so if you had manual windows and wanted to install later door panels your window crank won't work. You can swap in the later regualtor use an aftermarket crank handle. There were a few other things that varied in doors. Some had extra bracing including for the mirrors too. Some doors had an extra weather stripping too but I never understood why
« Reply #11 on: February 19, 2008, 06:25:22 pm »
77-91 door panels will swap with no problem.  The inside tract on the door is different also on the 73-76's.  this is turning it the door differences article I have planned to write.  :D
Offline 82chevy
« Reply #12 on: February 19, 2008, 08:09:51 pm »
well Captkaos i wished i knew that before lol but since i already have it painted and installed i might as well try to make it work since its going to be covered by the panel anyways. but now that im thinking about it my door panel probably wouldnt fit anyways. now that im looking more closely to the pics i have a door thats a little different than both. ill try to get a pic of it.
also a little off topic but i replaced the weatherstripping that goes inside the door that the glass goes up in and now it seems almost to tight for it to go up. i have to force it up at the end. could this be because its brand new and not broken in yet?
« Last Edit: February 19, 2008, 08:31:53 pm by 82chevy »
