Projects Posts (NOT VEHICLES)
LWB to SWB Conversion
15
16
17
Topic: LWB to SWB Conversion (Read 332445 times)
2502
Re: LWB to SWB Conversion
Reply #225 on:
February 15, 2010, 11:49:56 pm »
ok, i'm biting ideas off of this truck, cuz i want mine to look almost identical.
www.facebook.com/twenty502
azfabguy
Reply #226 on:
June 21, 2010, 12:06:34 am »
i think i will tackle this project this weekend!
BBCurtiss
Reply #227 on:
July 04, 2010, 07:19:51 pm »
i think i'm going to do this soon. i've got the back half of a swb frame (was a trailer), so i think i'm gonna map in where to cut it so it's got all my holes and that already in place. any one have any idea if going that route if i'd be able to use a stock swb shaft? it's a 79 2wd if any one wants to know
if it ain't leaking, it's empty
Reply #228 on:
July 04, 2010, 07:46:10 pm »
You should be able too
azfabguy
Reply #229 on:
July 04, 2010, 10:42:40 pm »
i cut mine this weekend. not hard at all.
fitz
Reply #230 on:
July 05, 2010, 05:00:08 pm »
Quote from: azfabguy on July 04, 2010, 10:42:40 pm
Making the cut does not sound difficult, it's welding it back together that takes the skill.
Reply #231 on:
July 05, 2010, 05:30:35 pm »
Agreed, make sure everything is square. I put my rear axle on turn/slip plates to allow me to get it as close as possible.
azfabguy
Reply #232 on:
July 06, 2010, 09:24:21 pm »
i created marks on the rails to measure from. took it to the frame shop yesterday and had them verify it. it was dang straight!
Huntingf150
New Users
Reply #233 on:
August 31, 2010, 02:16:08 am »
What's up man I want to do he same thing u did with this truck my ques is what was the amount that u cut out and what was Your final measurement from the back of the cab to the end of the frame?
Reply #234 on:
August 31, 2010, 03:43:24 pm »
Info for cutting them are located here:
http://www.73-87chevytrucks.com/lwb_to_swb.htm
franky69c10
Reply #235 on:
February 02, 2011, 10:31:24 pm »
Plan on doing this 2 my longbed soon, quick question can i use the stock lwb gas tanks or do I gotta get swb tanks
Last Edit: February 02, 2011, 10:35:35 pm by franky69c10
Reply #236 on:
February 03, 2011, 01:18:59 pm »
have to have the shorter tanks.
slammed79
Thou shalt not drive stock
Reply #237 on:
February 06, 2011, 09:19:25 pm »
Bummer about the tank swap, I rather like the twenty galon on the 74. What size Blazer tanks fit behind the axle?
Praise the lowered
Reply #238 on:
February 08, 2011, 02:21:34 pm »
26 or 31 gallon.
slammed79
Reply #239 on:
February 11, 2011, 08:50:07 pm »
Thanks Chris!
Praise the lowered
15
16
17
