Projects Posts (NOT VEHICLES)
LWB to SWB Conversion
13
14
15
16
17
Topic: LWB to SWB Conversion (Read 332526 times)
Re: LWB to SWB Conversion
Reply #195 on:
February 09, 2009, 04:57:14 pm »
I have the 3.73's back in there now. I found my two rear slots probably 14 years ago for $50 bucks and the fronts at a swap meet. Too bad they don't make a 10" wide repro but that makes these wheels cooler I think. Also keep an eye on eBay.
campcrf
stroked
Reply #196 on:
February 09, 2009, 07:26:35 pm »
thanks for your info... the reason i ask about the ratio is because i am still undiced what to put in my 12 bolt... either 373 or 411, but unsure
Reply #197 on:
February 09, 2009, 07:28:22 pm »
what size tires do you have and what trans?
campcrf
stroked
Reply #198 on:
February 09, 2009, 09:42:18 pm »
i put an ATI t350 reverse manual behind a 500+hp 383 stroker (built) with a 3000 TS converter... i still need to buy another set of tires... drag radials.... i think between 26-28" tall???. (just to let you know I am not driveing highway much... just the drag strip and cruising around town)...(also ordering in an auborn posi) ... one wheel wonder just not cutting it...lol
(last summer i put a 700r4 "beefed up" tranny in and it only lasted 3 days so i switched to a well known name trans)... thanks
Stantonss
Reply #199 on:
March 06, 2009, 07:59:14 pm »
Man.... Amazing work!
Reply #200 on:
March 07, 2009, 06:02:17 am »
Thanks!
Campcrf I'd go with the 3.73
campcrf
stroked
Reply #201 on:
March 07, 2009, 10:21:08 am »
Vile, thank you
Why 3:73 before 4:11?
Reply #202 on:
March 07, 2009, 12:15:15 pm »
Without overdrive it'll be too much
campcrf
stroked
Reply #203 on:
March 07, 2009, 12:24:32 pm »
thanks vile
t_graham11
Reply #204 on:
April 06, 2009, 02:15:52 am »
Hi I was just wondering if you had to drill new holes for the shortbed to be attached, do you remember roughly how much you cut out I just want to make sure Im in the same ballpark with mine. It says the frame differences is 14 inchs but the diagrams I found it only says there's a difference of ten?
Reply #205 on:
April 06, 2009, 04:48:00 am »
14" behind the cab and 6" off of the back. You'll want to drill and elongate holes for the bed floor so you have room to play. You'll have to drill holes for the fuel tank brackets too.
1HI4x4
V30 Crew now a shortbed.....
Reply #206 on:
April 06, 2009, 10:37:36 am »
Man, what a wealth of info in this thread. I'm starting a short bed conversion this weekend, actually taking the short bed to the bodyshop tomorrow. I am cutting down a 1991 Crew Cab 4x4 and installing a shortbed. The truck has a 4" lift and 35's, I am going to do the Blazer/Burb tank also, and complete repaint. I'll take pics.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Reply #207 on:
April 06, 2009, 11:14:40 am »
Good luck with it!
t_graham11
Reply #208 on:
April 06, 2009, 03:56:09 pm »
hey I hate to pester you again with the 6 inch cut you make off the back does it interfear with the crossmember?
Reply #209 on:
April 06, 2009, 04:12:33 pm »
the rear crossmember? No...
13
14
15
16
17
