Author Topic: roller  (Read 6858 times)
Offline mikewb
roller
« on: February 21, 2008, 01:36:05 pm »
anybody know if the made a roller 350 in the 88 to 95 model motors for truck
Re: roller
« Reply #1 on: February 21, 2008, 01:47:20 pm »
yes, after about 92 all motors are roller cams, if that is what you are talking about.
Offline HAULIN IT
Re: roller
« Reply #2 on: February 21, 2008, 02:11:27 pm »
Chris, I believe it is later than '92 as to all, I know some had them, but I think it is '96 that all had rollers. Some of the transition years had "roller" blocks (have the bosses for the lifter spider & front thrust plate) but had flat tappet cams. I helped a friend do a Vortec head & roller cam swap in his '95 truck. It had the roller block,but a flat tappet cam. His was a shortbed 1/2 ton 4x4. It had 66,000 miles. We used a GM kit, it came with the intake,one exhaust manifold,ect. Lorne
Offline mikewb
Re: roller
« Reply #3 on: February 21, 2008, 02:46:48 pm »
what all is needed to make a regular one a roller. if i get roller cam do i have to have roller lifters and roller rockers
Offline HAULIN IT
Re: roller
« Reply #4 on: February 21, 2008, 03:05:07 pm »
Mike, To use the factory parts, you need to have a roller compatible block,the cam,lifters,lifter spider,pushrods,front thrust plate. There may be a few other parts, timing chain gear,distributor gear,ect, without research that is all I can think of, Lorne
Re: roller
« Reply #5 on: February 21, 2008, 04:19:59 pm »
What makes a roller cam a roller cam is the fact that it has roller lifters.
Offline ccz145a
Re: roller
« Reply #6 on: February 21, 2008, 05:51:02 pm »
Quote
Quote from: mikewb on Today at 02:46:48 PM
and a profile too aggresive for flat tappets.
Re: roller
« Reply #7 on: February 22, 2008, 12:23:39 pm »
Did some checking and that is correct, 1996 was the official across the board for rollers in trucks.  Cars got them earlier.  I have seen a 88-95 pickups w/ a roller before factory though.  Guess it was like everything else GM, hit or miss.
