Author Topic: Need Wiring Order for 1984 Headlight Switch  (Read 16042 times)
Offline soiset
« on: February 21, 2008, 06:06:22 pm »
Hello, first post here.  I have a beautiful 1984 Silverado 4x4 in Dallas that I bought from the first owner in Raleigh, NC.  I've had it for 10 years now, and probably will have it forever.
Not too long ago, I ran into a bit of an emergency with the headlights.  The switch had been gimpy for a while, but I'd always been able to wiggle it into working.  I was about an hour away from home, on a craigslist run, and at dusk, I simply could not get the lights to come on.  Hungry, tired, and a little cold, I quickly narrowed the problem to the switch, and came up with a quick fix.  I pulled the wires out of the switch, did some experimenting, and hotwired my lights on.  I made it back home.
Now, I've ordered a new switch, but I have no idea where the 4 wires go.  I'm here to beg someone to look at theirs, and either snap a picture, or describe the layout, e.g. "red wire to left front, yellow wire to right front, etc."
I would very much appreciate some assistance.  I need my truck-truck* back!
*After we (my wife, now, and I) bought it, we heard the owner's wife call out, somewhat sadly as we drove off, "Goodbye, truck-truck!"  The name stuck.
Offline JJSZABO
Re: Need Wiring Order for 1984 Headlight Switch
« Reply #1 on: February 21, 2008, 07:47:12 pm »
This is from my Painless wiring manual - VERY similar:
Follow the instructions under10.6.1 - ignore my notes.
Lousy scan.
Note 10.6.1 says NOTE:   On late-style GM headlight switches, the park lights terminal to which wire 927 (brn) is connected (shown in Figure 10-6) has been omitted. In this case, wire 927 must be connected as indicated by the dash line in Figure 10-6.
« Last Edit: February 21, 2008, 07:50:24 pm by JJSZABO »
Jeff
86 Chevy C-10
350, TH400
Offline soiset
« Reply #2 on: February 21, 2008, 08:44:33 pm »
Thanks for the reply.  I forgot to mention that my truck is past inspection, so this is a pretty critical fix (a man is crippled without his truck, you know).  I think I can follow your scan; please correct me if I am wrong:  From left to right, it reads
Black dome and int light return
Red Blk
Brn
Blu/Ylw 14 ga
Brn 16 ga
Brn
Grn 14 ga
Offline soiset
« Reply #3 on: February 21, 2008, 08:47:18 pm »
Crap.  My wires are white, green, yellow, orange, orange, and brown.  No stripes, no red, no blue.
Offline JJSZABO
« Reply #4 on: February 21, 2008, 08:54:24 pm »
Ok according to my old stock switch that I cut the wires from it is:
White to 961 BLK
Red to 928 RED/BLK
Yellow to 907 BLU/YLW
green to 930 BRN
both orange to 959 ORN
brown to 929 BRN
That I know is correct.
This is better:
« Last Edit: February 21, 2008, 09:08:08 pm by JJSZABO »
Jeff
86 Chevy C-10
350, TH400
Offline soiset
« Reply #5 on: February 21, 2008, 09:14:42 pm »
Now THAT I can follow.  I've traced it out on my old switch, and it seems to make sense.  Thanks for your help.  I'll try to get a picture of truck-truck on here to show my appreciation.
Offline soiset
« Reply #6 on: February 21, 2008, 09:18:39 pm »
Did you go to an aftermarket switch?
Offline JJSZABO
« Reply #7 on: February 21, 2008, 09:22:07 pm »
Yes, since I am rewiring my truck with a Painless wiring harness, I am using a Painless headlight switch.  That's why the wire colors don't exactly match up.
Jeff
86 Chevy C-10
350, TH400
Offline Mtrhd329
« Reply #8 on: February 22, 2008, 12:53:00 am »
FWIW
Red- constant 12v
Green- dash lamps
Lt. Green- Rear running/park lamps
Tan- Front running/park lamps
White- interior lamp switch
Blue- to dimmer switch input
