Electrical
wiring
7
8
9
Topic: wiring (Read 133378 times)
HAULIN IT
Re: wiring
Reply #105 on:
March 13, 2008, 07:18:52 pm »
Ok, In that picture it is just sitting there, sticking up like that? After seeing the wiring job someone did, thought no question was foolish on this one. Good Luck & Have Fun, Lorne
hotrod24
Re: wiring
Reply #106 on:
March 13, 2008, 07:30:31 pm »
thank you
1978 pontiac grand prix...
hotrod24
Re: wiring
Reply #107 on:
March 13, 2008, 07:50:23 pm »
hey i just wanted to see if i am do this right ok the first pic is a 12 gauge wire with a 14 gauge fuse link this one goes from the stater to the block on the firewall and the second one is them wires i was talking about earlier i did not know what gauge it was so i put 2 gauges smaller like you said before.
Last Edit: March 13, 2008, 10:15:33 pm by hotrod24
hotrod24
Re: wiring
Reply #108 on:
March 14, 2008, 01:45:37 pm »
so vile what do you think am i doing right
Re: wiring
Reply #109 on:
March 14, 2008, 04:02:57 pm »
I think so.... however it looks like your fusible link is too long. they should be about 6" long
hotrod24
Re: wiring
Reply #110 on:
March 14, 2008, 04:10:35 pm »
that is what i thought i need some more connectors so as soon i get them i will Finish
hotrod24
Re: wiring
Reply #111 on:
March 17, 2008, 04:22:28 pm »
hey just curious do i need to put a fues link on the wire that goes to the s on the starter from the ingnition switch
Re: wiring
Reply #112 on:
March 17, 2008, 05:05:55 pm »
No that wire is circuit protected through the ignition switch circuit protection.
hotrod24
Re: wiring
Reply #113 on:
March 17, 2008, 06:37:57 pm »
ok good i put some of the wires on the starter does this look good
Re: wiring
Reply #114 on:
March 17, 2008, 08:14:37 pm »
NO, route them away from your header! Turn them towards the engine block especially your B+ cable. Make sure they are secured. You should wrap them away from the exhaust as much as possible. You have it connected right though!
Re: wiring
Reply #115 on:
March 17, 2008, 09:46:41 pm »
Yeah for sure. Flip the B+ over to the block side and put some zip ties and wrap it up.
hotrod24
Re: wiring
Reply #116 on:
March 17, 2008, 10:26:18 pm »
ok thank you
DnStClr
Re: wiring
Reply #117 on:
March 17, 2008, 10:42:14 pm »
hotrod, if I may add a small note- there should be 2 brass nuts on the stud coming out of your starter. The lower nut is used as a backup for the 2nd nut, with the wire terminals sandwiched between them. Using 2 nuts helps make sure that you don't overtighten and pull the brass stud loose. Ok?
Don
87 Chevy Silverado
hotrod24
Re: wiring
Reply #118 on:
March 17, 2008, 11:54:26 pm »
yea there are to nuts there the first one come lose so i tightend it
hotrod24
Re: wiring
Reply #119 on:
March 20, 2008, 06:55:27 pm »
ok vile i am done with the wiring it cracks good and runs better thank you
7
8
9
Electrical
wiring
