Electrical
wiring
8
9
Topic: wiring (Read 133349 times)
Re: wiring
Reply #120 on:
March 20, 2008, 07:14:56 pm »
Glad to hear man!
hotrod24
Re: wiring
Reply #121 on:
March 22, 2008, 12:06:04 am »
hey vile what does the block on the firewall do i only have that one wire going to it from the starter
1978 pontiac grand prix...
Re: wiring
Reply #122 on:
March 22, 2008, 07:44:29 am »
are you talking about the junction block on the firewall? The other peg should have a fusible link and a wire going to the field circuit on your alternator and you should also have a power feed fusible link to your fuse panel.
hotrod24
Re: wiring
Reply #123 on:
March 22, 2008, 10:51:03 am »
yea i am talking about the junction block well all them wires i showed you i thank one of them wires goes to the fuse panel and one goes to the alternator and the one going straight up i put it on the b+ on the starter solenoid with a fuse link
Re: wiring
Reply #124 on:
March 22, 2008, 10:56:36 am »
you did insulate that splice clip in that picture right?
hotrod24
Re: wiring
Reply #125 on:
March 22, 2008, 11:21:58 am »
i put black tap on it what should do how do i insulate it
Last Edit: March 22, 2008, 12:07:40 pm by hotrod24
Re: wiring
Reply #126 on:
March 22, 2008, 11:32:09 am »
electrical tape and some covoluted tubing or split loom
Here's some pimped out chromey ones if you wanna get fancy
http://www.taylorvertex.com/hp/index.cgi/chromeTubing
hotrod24
Re: wiring
Reply #127 on:
March 22, 2008, 12:15:05 pm »
man thanks i will get some of that i have seen stuff like that before but that is cool
hotrod24
Re: wiring
Reply #128 on:
March 22, 2008, 01:09:03 pm »
ok if i get some of the spit loom will i be good
Last Edit: March 22, 2008, 01:11:02 pm by hotrod24
Re: wiring
Reply #129 on:
March 22, 2008, 02:33:33 pm »
tape up any exposed connections or coat them good with liquid electrical tape. Then put all your wires nice n neat in the looms. Secure them and keep them out of harms way and you'll be good to go.
hotrod24
Re: wiring
Reply #130 on:
March 22, 2008, 03:07:26 pm »
ok man
8
9
Electrical
wiring
