Author Topic: wiring  (Read 133355 times)
Re: wiring
« Reply #120 on: March 20, 2008, 07:14:56 pm »
Glad to hear man!
Offline hotrod24
Re: wiring
« Reply #121 on: March 22, 2008, 12:06:04 am »
hey vile what does the block on the firewall do i only have that one wire going to it from the starter
1978 pontiac grand prix...
Re: wiring
« Reply #122 on: March 22, 2008, 07:44:29 am »
are you talking about the junction block on the firewall? The other peg should have a fusible link and a wire going to the field circuit on your alternator and you should also have a power feed fusible link to your fuse panel.
Offline hotrod24
Re: wiring
« Reply #123 on: March 22, 2008, 10:51:03 am »
yea i am talking about the junction block well all them wires i showed you i thank one of them wires goes to the fuse panel and one goes to the alternator and the one going straight up i put it on the b+ on the starter solenoid with a fuse link
Re: wiring
« Reply #124 on: March 22, 2008, 10:56:36 am »
you did insulate that splice clip in that picture right?
Offline hotrod24
Re: wiring
« Reply #125 on: March 22, 2008, 11:21:58 am »
i put black tap on it what should do how do i insulate it
« Last Edit: March 22, 2008, 12:07:40 pm by hotrod24 »
Re: wiring
« Reply #126 on: March 22, 2008, 11:32:09 am »
electrical tape and some covoluted tubing or split loom
Here's some pimped out chromey ones if you wanna get fancy
http://www.taylorvertex.com/hp/index.cgi/chromeTubing
Offline hotrod24
Re: wiring
« Reply #127 on: March 22, 2008, 12:15:05 pm »
man thanks i will get some of that i have seen stuff like that before but that is cool
Offline hotrod24
Re: wiring
« Reply #128 on: March 22, 2008, 01:09:03 pm »
ok if i get some of the spit loom will i be good
« Last Edit: March 22, 2008, 01:11:02 pm by hotrod24 »
Re: wiring
« Reply #129 on: March 22, 2008, 02:33:33 pm »
tape up any exposed connections or coat them good with liquid electrical tape. Then put all your wires nice n neat in the looms. Secure them and keep them out of harms way and you'll be good to go.
Offline hotrod24
Re: wiring
« Reply #130 on: March 22, 2008, 03:07:26 pm »
ok man
