Original leafs?
Topic: Original leafs? (Read 9069 times)
got2haul
Original leafs?
February 27, 2008, 09:25:37 am »
Anyone know what the original leaf spring configuration is for a 1/2 ton short box? I presume 1973-1987s were all the same except the heavy halfs? Mine has an RPO that says heavy duty rear springs, code 1G50; however I have 5 leafs with no overload spring. (I suspect the overload spring was removed by a previous owner.)
1980 Custom Deluxe Stepside
Stepside thread:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7505.0
1976 GMC Sierra Grande C15
HAULIN IT
Re: Original leafs?
February 27, 2008, 09:38:45 am »
I would agree with your assumption that the overload was removed. Lorne
Re: Original leafs?
February 27, 2008, 10:12:19 am »
yup all the rear ones cames with the +1 spring. But the # of leaves depends on the specific truck. Mine had 7 I just replaced them with 8+1 and took out the +1 and made it 8. It didn't effect the ride height
Re: Original leafs?
February 27, 2008, 10:18:54 am »
Generally speaking on the 73-80 (not 100% of the exact termination) the 53" = 3+1, THE 56" = 5+1. The 81-87 were 53" = 5+1 and 56" = 7+1. There were more scenarios though as Vile pointed out.
Re: Original leafs?
February 27, 2008, 12:14:03 pm »
My 1980 C-10 Custom Deluxe had 8+1 from the factory (originally Diesel Truck)
got2haul
Re: Original leafs?
February 27, 2008, 02:47:27 pm »
The leaf spring length measurements you mention... how is the measurement determined? For example, center of eye to center of eye in a straight line or center of eye to center of eye, following the arch of the spring, or some other way? I'd like to measure mine to see what it is I actually have. The truck has several 1981 parts on it (i.e. a motor from a 1981 GMC), so it could be that the springs are later model, too.
Stepside thread:
Re: Original leafs?
February 27, 2008, 03:09:56 pm »
Eye to eye (relaxed). 53 is the standard spring, 56 is the HD spring. The perch on the rear will be a lot closer to the rear of the frame.
Re: Original leafs?
February 27, 2008, 05:33:55 pm »
Mine have always been 56", never had 53". I thought all the shortbeds had the shorter spring no?
Re: Original leafs?
February 27, 2008, 05:39:52 pm »
Short bed Heavy Half, HD or Big Ten all had 56" springs on the LWB or SWB, same goes for the Long beds.
Re: Original leafs?
February 27, 2008, 05:41:58 pm »
Didn't know that... but now I do
joesgarage71
Wrench
Re: Original leafs?
February 28, 2008, 10:12:41 am »
My 78 K-20 SWB has 53" springs in the rear. My friend has a 80 K-10 SWB and a 79 C-10 SWB with 56"springs.
I broke a L/rear top and had a hard time finding a used one.
Original leafs?
