Author Topic: loose shift lever  (Read 3923 times)
Offline GUILLERMOARIAST
loose shift lever
« on: February 28, 2008, 07:32:56 pm »
Hello, my 4x4 1980 Blazer has a mechanic gearbox. The problem is that both shift levers are loose, they have a slight movement in every position, including neutral.
My mechanic told me this is normal, but i doubt it.
What do you think?
____________________________________________
Guillermo Arias, Lima- Perú
Re: loose shift lever
« Reply #1 on: February 28, 2008, 07:41:20 pm »
what transmission do you have? Check the linkage
« Reply #2 on: February 29, 2008, 12:32:06 pm »
If it is a manual 4 speed, they are loose, the t-case shifter can be considered loose, but you can adjust it some...
