Author Topic: Heads  (Read 10290 times)
Offline mikewb
Heads
« on: March 03, 2008, 12:50:07 am »
anybody know what head this is? i found this number 8986889X or 3986339X
Offline joesgarage71
  • Wrench
Re: Heads
« Reply #1 on: March 03, 2008, 07:11:37 am »
339X is a 1971 307/350 74 CC head
 couldn't find the 889X you must have read it wrong 3's 9's 8's look alike and sometime the casting gets sloppy. If they are near the same date there most likely from the same motor.
 Steve
Offline mikewb
Re: Heads
« Reply #2 on: March 03, 2008, 03:11:38 pm »
was trying to figure out what valves
Offline red4wd
Re: Heads
« Reply #3 on: March 03, 2008, 03:48:14 pm »
I saw them listed as 1.72 and 1.50
Offline mikewb
Re: Heads
« Reply #4 on: March 03, 2008, 04:53:37 pm »
is that a bad head to have?
Re: Heads
« Reply #5 on: March 03, 2008, 05:42:23 pm »
What are using it for?
Offline mikewb
Re: Heads
« Reply #6 on: March 03, 2008, 06:27:17 pm »
there on my motor right now. 350
Re: Heads
« Reply #7 on: March 04, 2008, 11:04:42 am »
I meant when you say are they bad in what reference are you asking?  If you are asking if they are a good performance head then the answer is no.  If you are asking if they are a good head in general, they would be a good low rpm head.
Offline mikewb
Re: Heads
« Reply #8 on: March 04, 2008, 02:29:39 pm »
i meant for performance
Offline mikewb
Re: Heads
« Reply #9 on: March 05, 2008, 07:20:32 pm »
should the numbers on both heads match or are they different?
Re: Heads
« Reply #10 on: March 05, 2008, 10:15:23 pm »
The should[/b] be the same on both sides.
Offline mikewb
Re: Heads
« Reply #11 on: March 05, 2008, 10:18:35 pm »
I have these . left 3946813 right 3986339X
  • Wrench
Re: Heads
« Reply #12 on: March 08, 2008, 11:02:04 am »
3946813= 69-79 350 truck. And you know the other one. The casting numbers should match but I have seen untouched motors that had different heads on them from the factory.
