Performance
Heads
Topic: Heads (Read 10285 times)
mikewb
Heads
March 03, 2008, 12:50:07 am »
anybody know what head this is? i found this number 8986889X or 3986339X
joesgarage71
Wrench
Re: Heads
March 03, 2008, 07:11:37 am »
339X is a 1971 307/350 74 CC head
couldn't find the 889X you must have read it wrong 3's 9's 8's look alike and sometime the casting gets sloppy. If they are near the same date there most likely from the same motor.
Steve
mikewb
Re: Heads
March 03, 2008, 03:11:38 pm »
was trying to figure out what valves
red4wd
Re: Heads
March 03, 2008, 03:48:14 pm »
I saw them listed as 1.72 and 1.50
mikewb
Re: Heads
March 03, 2008, 04:53:37 pm »
is that a bad head to have?
Re: Heads
March 03, 2008, 05:42:23 pm »
What are using it for?
mikewb
Re: Heads
March 03, 2008, 06:27:17 pm »
there on my motor right now. 350
Re: Heads
March 04, 2008, 11:04:42 am »
I meant when you say are they bad in what reference are you asking? If you are asking if they are a good performance head then the answer is no. If you are asking if they are a good head in general, they would be a good low rpm head.
mikewb
Re: Heads
March 04, 2008, 02:29:39 pm »
i meant for performance
mikewb
Re: Heads
March 05, 2008, 07:20:32 pm »
should the numbers on both heads match or are they different?
Re: Heads
March 05, 2008, 10:15:23 pm »
The
should[/b] be the same on both sides.
mikewb
Re: Heads
March 05, 2008, 10:18:35 pm »
I have these . left 3946813 right 3986339X
joesgarage71
Wrench
Re: Heads
March 08, 2008, 11:02:04 am »
3946813= 69-79 350 truck. And you know the other one. The casting numbers should match but I have seen untouched motors that had different heads on them from the factory.
Performance
Heads
