Author Topic: 1 piece rear main block  (Read 4800 times)
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
« on: March 03, 2008, 11:27:25 pm »
Will a 1 piece rear main block bolt right up to a two piece blocks motor mounts and accessories as in swap right in?
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline monte85
Re: 1 piece rear main block
« Reply #1 on: March 04, 2008, 12:44:38 am »
i'm assuming you are talking small blocks(i know jack about big blocks). i believe everything is the same. the only thing that changes is the flywheel.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
« Reply #2 on: March 04, 2008, 01:01:06 am »
K once piece blocks are externally balanced correct? I'm looking at crate motors and they offer both i was just thinking the one piece because of ease of changing the seal. They're 383 strokers so I'll have to change the flywheel anyways.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
« Reply #3 on: March 04, 2008, 10:34:40 am »
They are still Gen I blocks so everthing will mount the same, the flexplate won't be the same.
Offline monte85
« Reply #4 on: March 04, 2008, 10:50:50 am »
i'm glad someone knew. i have been looking through my motor building books for an answer to the balancing question.
