Author Topic: torque converter bolts  (Read 10084 times)
woodtick
  • Guest
« on: May 11, 2002, 02:27:00 pm »
I have an 86 k5 Blazer with a 305 and a 700r4 trans the only problem i have with the truck is that the @##@$%^%%$&&**&&**torque converter bolts keep coming loose . iv tried loc-tite that dont work. what causes this problem and how can i fix it .         thanks woodtick
Re: torque converter bolts
« Reply #1 on: May 27, 2002, 07:23:00 pm »
I use loc-tite and they never come loose. Are you tightening them enough? Are you using the correct bolts?
~Captain's Log~
Offline ChevyGuy
hmmm
« Reply #2 on: May 29, 2002, 12:09:00 am »
Ive had a friend that decided he was goin to use torque convertor bolts off a newer model motor... bad idea.. they were metric. Or you can go to Autozone and get a good set from Mr Gasket.
oscarone
  • Guest
bolts
« Reply #3 on: August 03, 2002, 04:30:00 pm »
Go to the store and find a new set of bolts that apply to your tranny.  The important thing is, since the nuts are "self locking", that you use a new set.  USE A NEW SET!
Offline RSBAD454
Re: bolts
« Reply #4 on: September 19, 2002, 04:43:00 pm »
go to www.summitracing.com and get a set of ARP Torque Converter bolts and or goto your local chevrolet dealership parts department and get the correct set. i have never heard of anyone with this problem.
http://
4wheelinbooty
  • Guest
bolts
« Reply #5 on: September 24, 2002, 10:21:00 am »
i had the same problem just do what the other guy said and get the arp bolts
