Author Topic: Slip Yoke/Driveline U-joints from a NP203 fit up to a NP208?  (Read 15739 times)
Offline Mike Phillips
« on: March 04, 2008, 05:23:01 pm »
Okay, got the tranny and transfercase in, but I didn't get any drivelines or the slip yoke and/or associated parts with the the transfercase when I bought it.  There's a guy parting out a 1985 Blazer but it has a full-time front end, I'm guessing this means his transfercase is a NP203?
Will the slip yoke coming out of a NP203 work with my NP208?   And same question for the front driveline coming off the front output shaft?
How about the shifter and shifter linkage for the transfercase, does NP203 bolt up to NP208?
Here's an update...
First, I need a slip Yoke for the rear output shaft on the 700R4
Rear Output Shaft on a NP208
Then I need the component that attaches to the Front Output Yoke that will then connect to the U-joints on the front driveline.
Front shot
Underneath shot
Argh....
« Last Edit: March 04, 2008, 06:29:14 pm by Mike Phillips »
Re: Slip Yoke/Driveline U-joints from a NP203 fit up to a NP208?
« Reply #1 on: March 04, 2008, 09:45:40 pm »
The front shaft is a doublr cardan joint that bolts dirctly to the companion flange. The slip yoke is part of the shaft.
« Reply #2 on: March 04, 2008, 10:48:40 pm »
Found a guy on CraigsList parting out a 4x4 Chevy Suburban, says it's either 1981 or 1984 as there are two dates on his assorted paperwork for the vehicle.  He says the running gear is a 700R4 mated to a NP208 transfercase and it has both drivelines still looked up as well as the complete shifter for the Transfercase.  3 Things I need.
Here's the ad,
http://inlandempire.craigslist.org/pts/592621203.html
1981 chevy 2500 4x4 parting out no motor other wise complete. good trans. with transfer case, has damage on both finders and drivers side door. email me for parts prices, saturday and sunday only. goes to scarp on monday. parts only so dont ask for the whole thing. has junk slip already.
it has 208, both drive shafts are still there . the frount should be the same.
Unless someone here doubts what the running gear may actually be, I'm going to go dismantle this thing tomorrow morning for the parts I need.
« Last Edit: March 04, 2008, 10:51:44 pm by Mike Phillips »
Offline 76_Scottsdale
  • I'd rather push my Chevy than drive a Ford
« Reply #3 on: March 05, 2008, 01:33:02 am »
You could always do a slip-yoke eliminator kit on the NP208 and use the same driveline as before just shortened a little.
1976 Scottsdale K20
350 C.I.D.
700R4
NP205
2 1/2" Lift
305/70/R16 BFG MT
True Dual 3" Flowmaster 40 Series Exhaust
Offline Dragon
« Reply #4 on: March 05, 2008, 02:57:40 am »
Mike check this out to use your current parts(with modified drive shafts ofcourse!)..
https://eshop.advanceadapters.com/commerce/ccc1026-transfer-case-adapters.htm
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
