Author Topic: NEED HELP!!!  (Read 10753 times)
Offline crazedhick3
NEED HELP!!!
« on: March 04, 2008, 07:32:24 pm »
I lost my speedometer function today on my 89 suburban.  Pulled the gear and sure enough it was chewed all to heck.  Checked the gear inside the tailshaft cover and that one is eat up  too.  Pulled the tailshaft cover on the end and exposed the bearing.  My question is, What is the best way to pull the C clip that retains the bearing so I can get other cover pulled to get to the gear?
Re: NEED HELP!!!
« Reply #1 on: March 04, 2008, 07:53:04 pm »
Make sure the cable spins free and isn't the cause of the destruction of the gear. Is this a 4wd or 2wd Suburban?
Offline crazedhick3
Re: NEED HELP!!!
« Reply #2 on: March 04, 2008, 08:20:50 pm »
Cable is fine.  4wd.  Pulled the cone shaped tailshaft cover.  The second cover is loose but there is a clip retaining the bearing from sliding off the shaft.  I can probably pry this off but it is real tight and i dont want to break the clip.  Is there a tool for this?
Re: NEED HELP!!!
« Reply #3 on: March 04, 2008, 09:33:07 pm »
Do you have a 241 Transfer case?
Offline crazedhick3
Re: NEED HELP!!!
« Reply #4 on: March 05, 2008, 07:46:07 pm »
NP203
Re: NEED HELP!!!
« Reply #5 on: March 06, 2008, 06:55:45 am »
203 in an 89?
Offline DnStClr
Re: NEED HELP!!!
« Reply #6 on: March 06, 2008, 11:07:03 am »
When you buy the new gear it should include a new clip too, or at least a clip should be available.
Don
87 Chevy Silverado
Offline crazedhick3
Re: NEED HELP!!!
« Reply #7 on: March 06, 2008, 04:28:40 pm »
Blazin and Zambonie, Im sorry it is a 241 case.  I was thinking of my older case for my 77.  I was able to work on it again today and got the snap ring off, but I dont want to pull on the cover until I know "crap aint gonna fly everywhere".  I hope you guys can follow what im trying to do. I want to change the speedometer gear thats inside the case and is slipped on the output shaft.  Can it be done while still in the truck?  I would post pics but I can never get them to work on this site.
Re: NEED HELP!!!
« Reply #8 on: March 06, 2008, 05:24:33 pm »
have you seen this post on uploading pics; http://forum.73-87chevytrucks.com/smforum/index.php?topic=6428.0
Offline crazedhick3
Re: NEED HELP!!!
« Reply #9 on: March 06, 2008, 06:13:06 pm »
Thanks Chris.  Im sure that will help.
Re: NEED HELP!!!
« Reply #10 on: March 06, 2008, 07:51:40 pm »
Didn't look at the link but you need to pull the snap ring and the bearing off it it's a 241 then the gear slides off with a little persuasion.
Offline crazedhick3
Re: NEED HELP!!!
« Reply #11 on: March 07, 2008, 06:57:27 am »
Ok, I will try later tonight.  I just asked because when I started to pull the cover with the bearing, the shaft felt real floppy without the bearing supporting it and I didnt want to go to far and have to yank the whole tcase out of the truck.  I didnt think it would get this involved when i started this.  I JUST WANT MY CRUISE CONTROL BACK!!!    :)
Offline crazedhick3
Re: NEED HELP!!!
« Reply #12 on: March 07, 2008, 05:11:20 pm »
Finally, I got to work on it long enough to get it apart.  I had to be a little more aggressive than what I wanted to be but everything came apart ok.  Here are some pics so you guys can see what I been trying to tell you.
Offline crazedhick3
Re: NEED HELP!!!
« Reply #13 on: March 07, 2008, 05:25:17 pm »
Just got an idea.  Cant I just flip the gear that was on the output shaft around and use the other side?  Or is that being too cheap?   :D
Re: NEED HELP!!!
« Reply #14 on: March 07, 2008, 05:26:46 pm »
That's being pathetically cheap
