Author Topic: chassis saver  (Read 13425 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
chassis saver
« on: March 07, 2008, 04:37:31 pm »
where are you guys getting this stuff? the guys at autozone, oreillys and parts america just give me a blank stare. Thanks
Offline Toolmaster
Re: chassis saver
« Reply #1 on: March 07, 2008, 04:49:19 pm »
Are you talking about Por 15 ?
http://www.por15.com/
Re: chassis saver
« Reply #2 on: March 07, 2008, 04:50:38 pm »
Re: chassis saver
« Reply #3 on: March 07, 2008, 07:22:13 pm »
Any good paint store should have it.
Offline HAULIN IT
Re: chassis saver
« Reply #4 on: March 07, 2008, 08:30:42 pm »
Have you checked at a local autobody supply store, as Chris suggested? I have used it several times (the store my brother works at, carries it) One thing I have noticed with it & Por-15, if your using semi- gloss, if you spray it & brush it, the shine comes out a little different, so plan ahead. Lorne
Re: chassis saver
« Reply #5 on: March 08, 2008, 12:57:18 am »
If you spray it make sure your face is covered with a face shield. I knew it didn't come off your hands, but I forgot about my face when I sprayed it. I had the cheetah look for about a week!
Offline monte85
Re: chassis saver
« Reply #6 on: March 08, 2008, 03:50:35 am »
the only thing i've ever used is rust encapsulator from eastwood. its on the frame, cab floor and bed support channels. i like the stuff.
"Of my friend, I can only say this: of all the souls I have encountered in my travels, his was the most... human."
Re: chassis saver
« Reply #7 on: March 08, 2008, 05:54:42 am »
LOL
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: chassis saver
« Reply #8 on: March 08, 2008, 10:32:22 am »
blazin, your the man! thats funny. Jeremy
Offline JJSZABO
Re: chassis saver
« Reply #9 on: March 11, 2008, 11:34:10 am »
 :D :D
This is what I use, but for underneath the bed I am trying Chasis saver.
Jeff
86 Chevy C-10
350, TH400
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: chassis saver
« Reply #10 on: March 22, 2008, 04:05:48 pm »
I finally found chassis saver locally at a store called Specialty Paints. Thanks
Offline ssgoodman
Re: chassis saver
« Reply #11 on: March 22, 2008, 08:28:18 pm »
would this be equivilant to Rust Bullet?  i am looking for something to put under the Jimmy for rust protection and was considering Rust Bullet since reading an article on K5 colorado about it.
Offline 80stepsideguy
Re: chassis saver
« Reply #12 on: March 22, 2008, 08:30:40 pm »
I`m using this stuff on my frame of the truck and i am having a friedn use it on his 99 ram as well right now. this stufi s awesome.
thanks
pat
http://www.kbs-coatings.com/
1998 Chevy 1500 S/B 2wd
Offline ssgoodman
Re: chassis saver
« Reply #13 on: March 22, 2008, 11:15:16 pm »
i see that KBS has a gas tank sealer kit, have you tried that?  i want to avoid buying a new one if possible.
Re: chassis saver
« Reply #14 on: March 23, 2008, 12:06:54 am »
Cant say i ever used this stuff, i heard alot of bad comments bout gas tank sealers as they can clog up the lines and also cause more damage then good.
thanks
pat
