Author Topic: changed oil last weekend  (Read 5293 times)
Offline chevyboy1983
« on: March 09, 2008, 05:31:05 pm »
i changed my oil last on a 1983 chevy 1/2 k10 w/ rebuilt 1976 engine in it. How many quarts does it take for this year truck? The reason i was asking i only used 4 quarts 3 for the engine and 1 for the filter.
« Last Edit: March 09, 2008, 05:37:54 pm by chevyboy1983 »
Offline 77c15
  • combustion=suck, squeeze, bang, blow
    • My cardomain site...
Re: changed oil last weekend
« Reply #1 on: March 09, 2008, 05:52:02 pm »
Small block chevy = 4 1/2 qts
Chrysler crossfire v6 = 8 1/2 qts
« Reply #2 on: March 09, 2008, 05:54:41 pm »
ok thanks i was just wondering cause i thought it took more oil than that first time changing myself on this truck
« Reply #3 on: March 09, 2008, 06:40:10 pm »
Did youc check it after you started it?
Offline 77c15
« Reply #4 on: March 09, 2008, 06:49:39 pm »
If you check out Auto Zone, they usually have an "oil change special" where they sell you 5 quarts and a filter for anywhere from $8.99 - $14.99. The reasoning behind the 5 quarts is because the majority of all gasoline powered vehicles on the road today take 4 1/2 quarts from the factory. If you have a larger oil pan or a different dry/wet sump system, then it's different. Big blocks are also different. Diesels are different. But 90% of the gas powered 4, 6, and 8 cylinder gasoline engines take 4 1/2 quarts.
« Reply #5 on: March 09, 2008, 06:54:40 pm »
yea it is ready full on the dipstick.  I just thought the engine took more oil than that
« Reply #6 on: March 09, 2008, 07:44:17 pm »
My small blocks usually take just around 5. I get the engine hot before I drain it.
« Reply #7 on: March 09, 2008, 09:04:11 pm »
I did not want to get the engine up to operating temp because the truck sat for 4 years and i drained the oil out cold because i didnt want to do any damage to the engine b4 starting it up until i got new oil in it.
« Last Edit: March 09, 2008, 09:52:02 pm by chevyboy1983 »
