Author Topic: engine has no power  (Read 12397 times)
Offline plowking_90
engine has no power
« on: March 09, 2008, 06:05:02 pm »
i have a stall converter in my truck not sure on what size. i have a 350 with around 350 hp, motor is approx. 6 years old. i have eldelbrock performer intake, eldelbrock 650 carb with a miled cam, roller rockers, turbo 400. when im driving the truck it has no power i usualy run 36 inch super swampers and put 31 inch bf goodrich for the winter. it wont even spin the 31's, you would think it would be a rollerskate.......... i changed cap, rotor, plugs ,wires, fuel filter what are some other things i can look for to get my power back. maybe some carb.adjustments, timing, i bought the truck like this 1 year ago and im trying to work all the bugs out for this spring (MUD SEASON) and summer cruising
Offline Toolmaster
Re: engine has no power
« Reply #1 on: March 09, 2008, 06:14:12 pm »
What gears are in the diffs ?
Offline plowking_90
« Reply #2 on: March 09, 2008, 06:17:30 pm »
i did the turn the wheel thing to calculate the gear ratio and  i think its a 411 not possitive though, but even if it was stock gearing i have 350 hp it should be like butter on my tires with the 31's
Offline HAULIN IT
« Reply #3 on: March 09, 2008, 06:20:05 pm »
Plowking, Start with the basics. Do a compression test, is the engine is sound working condition? Then move on. Where is the timing at? Does the distributor advance with engine RPM? What do you have for fuel pressure? Is the cam degreed in correctly & so on. If you bought it this way you may need to "dig in" a little to find out what the last guy did or did incorrectly. You may have some mis-matched parts (low compression/cyl. pressure) that you can not fix without knowing what is in there. Good Luck, Lorne
Offline Swims350
    • Cars and trucks
« Reply #4 on: March 09, 2008, 06:30:55 pm »
gear ratio.
I ran into that in my monte carlo. Had a nice motor that came from a 76 truck would scream in the truck, had 2.11's in the car and it sucked. I put in a set of 3.42's and a shift kit and stall brung it right back.
Taller tires bring the gear ration numbers down further.
www.cardomain.com/id/benwa454
Offline plowking_90
« Reply #5 on: March 09, 2008, 06:36:44 pm »
what is the gear ratios these trucks came with mine is a 1980 1/2 ton lwb
« Reply #6 on: March 09, 2008, 06:39:17 pm »
You probably have 2.73's lol
Put it in low range and see if it has sack.
Offline plowking_90
« Reply #7 on: March 09, 2008, 06:44:31 pm »
how hard??? and how much money am i looking at for better gearing front and rear?
Offline Toolmaster
« Reply #8 on: March 09, 2008, 07:07:16 pm »
What's your plans for this truck ?  D/D (daily driver) W/T and M/T (work truck mud truck)
Look in some of the Off Road forums and you might find a set of diffs ready to go.
A set of 60's could cost about 2k +/-
Dana44's would last for a while, But they have there week links when off-roading a full size truck.
Offline plowking_90
« Reply #9 on: March 09, 2008, 07:12:02 pm »
it gonna be a daily driver mud truck so it dosnt have to be special gearing but im gonna check again to se what i have for gearginf then ill go from there ill post my gearging tomarow to cold to deal with it right now
Offline Swims350
    • Cars and trucks
« Reply #10 on: March 09, 2008, 09:33:58 pm »
Well summit or jegs has ring and pinion sets for like $140-160 or so.
I think I'd get 3.73 or bigger for a mud truck or daily. If you put in 4.10's time you slap on 33's it take it down to like 3.73 or so I think maybe less. For real torque and power you could get 4.56's or something along those lines.
Offline 75??? franken-trunk
« Reply #11 on: March 10, 2008, 07:18:16 am »
i agree in your list i saw no vacuum advance diaphragm, i had a 68' 327, it seemed gutless... it maxed out a 3500 rpm. thats not right. so i pulled the hose for the vacuum advance diaphragm and sucked, i could suck air like nothin', so changed it. $10 two screws and 15 min. later i had a easy 6000 rpm and what seamed to be triple the power, thats my opinion.
Jack'em High
Fat chicks can't climb
Offline SUX2BU99
« Reply #12 on: March 10, 2008, 03:21:44 pm »
^ That sounds kinda like my truck. I should check that out on my HEI to see it's doing anything. Should be a strong suction in that tube when i take it off the canister?
« Reply #13 on: March 10, 2008, 03:52:18 pm »
If it's hooked to manifold vacuum yes.
Offline SUX2BU99
« Reply #14 on: March 10, 2008, 04:24:43 pm »
I have 3 hoses attached to the front of my Edelbrock carb. Big one in the middle goes to my PCV valve, another one goes to my vacuum canister and the other small one flanking the PCV hose connects directly to a hard line from my tranny (I presume for my vacuum modulator).
